11 hours ago, Nghia Trong said:
Archive.zip
remove voodooinput
Hi, I just installed my laptop, it has a temperature problem, if I use it normally it will be around 5x°C 6x°C, but if I watch the video on youtube the CPU temperature is up to 7x°C, Can you help me fix it? thanks so much!
http://www.mediafire.com/file/7suw8htm69jka14/Send_me_Quans-MacBook-Pro.zip
what ur hardware?
15 hours ago, MaLd0n said:
what ur hardware?
My laptop:
Acer V3 471G
i5 3210M 2.5GHz Boost 3.1GHZ
Intel HD 4000 + NVDIA 630M 2G.
Chipset Intel series 7
Ram 8G, SSD 128
11 hours ago, MaLd0n said:
Thank you, I've done this step already. I discovered the problem with Google chrome while watching the video. It is difficult to understand that when using Clover + Mojave, there was no this problem ?? I still think there's something I haven't done right !!!
Edited by thodan36b
I am setting opencore but it always stops at system start, I leave my EFI folder and an OC error message
00:000 00:000 AAPL: [EB|#LOG:INIT] 2020-10-12T06:13:56
00:002 00:002 AAPL: [EB|#VERSION] boot.efi 422.140.3~2 (Official), built 2020-06-07T17:22:20-0700
00:005 00:002 AAPL: [EB|#BUILD] BUILD-INFO[298]:{"DisplayName":"boot.efi","DisplayVersion":"422.140.3~2","RecordUuid":"B6FD6584-F0DA-41E8-9542-FAD5E7448407","BuildTime":"2020-06-07T17:22:20-0700","ProjectName":"efiboot","ProductName":"boot.efi","SourceVersion":"422.140.3","BuildVersion":"2","BuildConfiguration":"Release","BuildType":"Official"}
00:008 00:002 AAPL: [EB|#H:IS] 0
00:011 00:002 AAPL: [EB|#WL:MODE] 0
00:014 00:002 AAPL: [EB|#CONFIG:SRC] <default>
00:016 00:002 AAPL: [EB|#CONFIG| 0] boot-save-log : 0x0000000000000002 (0x0000000000000002 < 0xFFFFFFFFFFFFFFFF) <default>
00:019 00:002 AAPL: [EB|#CONFIG| 1] wake-save-log : 0x0000000000000002 (0x0000000000000002 < 0x0000000000000002) <default>
00:022 00:002 AAPL: [EB|#CONFIG| 2] console       : 0x0000000000000001 (0x0000000000000001 < 0x0000000000000001) <default>
00:025 00:002 AAPL: [EB|#CONFIG| 3] serial        : 0x0000000000000000 (0x0000000000000000 < 0x0000000000000000) <default>
00:028 00:002 AAPL: [EB|#CONFIG| 4] embed-log-dt  : 0x0000000000000000 (0x0000000000000000 < 0x0000000000000000) <default>
00:030 00:002 AAPL: [EB|#CONFIG| 5] timestamps    : 0x0000000000000000 (0x0000000000000000 < 0xFFFFFFFFFFFFFFFF) <default>
00:033 00:002 AAPL: [EB|#CONFIG| 6] log-level     : 0x0000000000000001 (0x0000000000000001 & 0x0000000000000001) <default>
00:036 00:002 AAPL: [EB|#CONFIG| 7] breakpoint    : 0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) <default>
00:039 00:002 AAPL: [EB|#CONFIG| 8] kc-read-size  : 0x0000000000100000 (0x0000000000100000 < 0xFFFFFFFFFFFFFFFF) <default>
00:042 00:002 AAPL: [EB|#H:IS] 0
00:044 00:002 AAPL: [EB|#WL|0] 0x01 0x01   0 0x00
00:047 00:002 AAPL: [EB|#BRD:NV] Mac-E43C1C25D4880AD6
00:050 00:002 AAPL: [EB|#WL|1] 0x01 0x01   2 0x00
00:053 00:002 AAPL: [EB|`BST:IDT] {
00:057 00:003 AAPL: [EB|`BST:IDT] }
00:059 00:002 AAPL: [EB|#WL|2] 0x01 0x01   3 0x00
00:062 00:002 AAPL: [EB|#WL|3] 0x01 0x01   4 0x00
00:065 00:002 AAPL: [EB|#BRD:NV] Mac-E43C1C25D4880AD6
00:068 00:002 AAPL: [EB|#WL|4] 0x01 0x01   5 0x00
00:071 00:002 AAPL: [EB|`H:CHK] BM: 0x0000000000000000
00:074 00:002 AAPL: [EB|`H:CHK] Err(0xE) @ GV boot-signature
00:076 00:002 AAPL: [EB|#WL|5] 0x01 0x01  23 0x0E
00:079 00:002 AAPL: [EB|`H:CPM] Err(0xE), (24, 24) @ GV Persistent-memory-note
00:082 00:003 AAPL: [EB|#SB:P] 0x1
00:085 00:002 AAPL: [EB|`B:MN] BM: +SB
00:088 00:002 AAPL: [EB|#LIMG:DP] Acpi(PNP0A03,0)/Pci(1F|2)/SATA(0,FFFF)/HD(Part2,Sig4C36300A-84AB-46B3-859F-1347F505FDA3)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842)
00:091 00:002 AAPL: [EB|#LIMG:FP] \68E6371B-82F3-4204-B56A-5F795EB5EAFA\System\Library\CoreServices\boot.efi
00:094 00:002 AAPL: [EB|#LIMG:OPT] ()
00:097 00:002 AAPL: [EB|`OPT:LXF] 'LF (\\68E6371B-82F3-4204-B56A-5F795EB5EAFA\\System\\Library\\CoreServices\\com.apple.Boot.plist)
00:099 00:002 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: \\68E6371B-82F3-4204-B56A-5F795EB5EAFA\\System\\Library\\CoreServices\\com.apple.Boot.plist, DP: 0
00:102 00:002 AAPL: [EB|`LD:OFS] Err(0xE) @ OPEN (\\68E6371B-82F3-4204-B56A-5F795EB5EAFA\\System\\Library\\CoreServices\\com.apple.Boot.plist)
00:105 00:002 AAPL: [EB|`OPT:LXF] Err(0xE) @ 'LF
00:108 00:002 AAPL: [EB|`OPT:LXF] 'LF (Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist)
00:111 00:002 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist, DP: 0
00:115 00:003 AAPL: [EB:#KF] ()
00:117 00:002 AAPL: [EB|#MBA:CL] ()
00:120 00:002 AAPL: [EB|#MBA:NV] (-v keepsyms=1 debug=0x100 alcid=28 slide=202)
00:123 00:002 AAPL: [EB|#MBA:KF] ()
00:126 00:002 AAPL: [EB|#MBA:OUT] (-v keepsyms=1 debug=0x100 alcid=28 slide=202 chunklist-security-epoch=0 -chunklist-no-rev2-dev)
00:129 00:002 AAPL: [EB|#LOG:VERBOSE] 2020-10-12T06:13:57
00:132 00:002 AAPL: [EB|`CSR:S] csr-active-config = 0x00000040
00:134 00:002 AAPL: [EB|#OPT:BM] 0x284182
00:137 00:002 AAPL: [EB|`OPT:LXF] 'LF (\\68E6371B-82F3-4204-B56A-5F795EB5EAFA\\System\\Library\\CoreServices\\PlatformSupport.plist)
00:140 00:002 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: \\68E6371B-82F3-4204-B56A-5F795EB5EAFA\\System\\Library\\CoreServices\\PlatformSupport.plist, DP: 0
00:144 00:004 AAPL: [EB|#B:VAw]
00:147 00:002 AAPL: [EB|#P:CPR] N
00:150 00:002 AAPL: [EB|#P:MPI] N
00:163 00:012 AAPL: [EB|#P:BPI] N
00:165 00:002 AAPL: [EB|`CS:CSKSD] {
00:168 00:002 AAPL: [EB|`CS:CSKSD] Err(0xE) @ GV 8D63D4FE-BD3C-4AAD-881D-86FD974BC1DF:boot-info-payload
00:171 00:002 AAPL: [EB|#WL|6] 0x01 0x01   6 0x0E
00:174 00:002 AAPL: [EB|`CS:LFC] {
00:181 00:007 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: System\\Library\\Caches\\com.apple.corestorage\\EncryptedRoot.plist.wipekey, DP: 0
00:191 00:009 AAPL: [EB|`FS:AGSVH] Err(0xE) @ LocHB 59D76AE4-37E3-55A7-B460-EF13D46E6020
00:193 00:002 AAPL: [EB|`G:CS] } Ok(0)
00:196 00:003 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: <null string>, DP: 1
00:202 00:005 AAPL: [EB|`B:SBS] SZ: 621112
00:211 00:008 AAPL: [EB|#B:SHA] f4031e1840ae80899574cd5a1feedc6b106d0f87
00:214 00:003 AAPL: [EB|`WL:PWLFNV] Err(0xE) @ GV wake-failure
00:217 00:002 AAPL: [EB|`WL:DT] Err(0xE) @ WL:PWLFNV
00:220 00:002 AAPL: [EB|`WL:PWLFRTC] ! @ RTC:R
00:223 00:002 AAPL: [EB|`WL:DT] Err(0xE) @ WL:PWLFRTC
00:226 00:002 AAPL: [EB|`FS:AGSVH] Err(0xE) @ 'AGU.0
00:229 00:002 AAPL: [EB|`FS:AGSVH] Err(0xE) @ 'AGU.1
00:232 00:002 AAPL: [EB|`FS:AGSVH] Err(0xE) @ 'AGU.2
00:235 00:003 AAPL: [EB|`LD:LKC] SB -> (System\Library\PrelinkedKernels\immutablekernel)
00:238 00:003 AAPL: [EB|`LD:LKC] BPDK -> (System\Library\PrelinkedKernels\immutablekernel.development)
00:242 00:003 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: System\\Library\\PrelinkedKernels\\immutablekernel.development, DP: 0
00:254 00:012 AAPL: [EB|`LD:OFS] Err(0xE) @ OPEN (System\\Library\\PrelinkedKernels\\immutablekernel.development)
00:257 00:003 AAPL: [EB|`LD:LKC] BPDK,!R -> (System\Library\PrelinkedKernels\immutablekernel)
00:260 00:003 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: System\\Library\\PrelinkedKernels\\immutablekernel, DP: 0
02:475 02:214 OC: Prelinked injection VoodooI2C.kext () - Invalid Parameter
02:529 00:054 OC: Prelinked injection VoodooI2CELAN.kext () - Invalid Parameter
03:324 00:795 AAPL: [EB|#SB:HW] j137ap\0
03:327 00:003 AAPL: [EB|#SB:MF] (System\\Library\\PrelinkedKernels\\immutablekernel.j137ap.im4m)
03:331 00:003 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: System\\Library\\PrelinkedKernels\\immutablekernel.j137ap.im4m, DP: 0
03:813 00:482 AAPL: [EB|#SB:MKRN]
03:833 00:020 AAPL: [EB|`LD:LKFS] } Ok(0)
03:836 00:002 AAPL: [EB|`LD:LKC] } Ok(0)
03:839 00:003 AAPL: [EB|#FWFM] 0xFF1FFF7F
03:842 00:002 AAPL: [EB|#FWFT] 0xFD0FF576
03:845 00:002 AAPL: [EB|#CSR:OUT] 0x00000040
03:848 00:002 AAPL: [EB|`BST:FBS] {
03:851 00:003 AAPL: [EB|`BST:FBS] BA.ADSZ: 0
03:854 00:002 AAPL: [EB|`BST:FBS] BA.KSDSZ: 0
03:857 00:003 AAPL: [EB|`B:WFDW] Err(0xE), 0 @ LocHB 71B4903C-14EC-42C4-BDC6-CE1449930E49
03:860 00:003 AAPL: [EB|#LOG:DT] 2020-10-12T06:14:00
03:863 00:003 AAPL: [EB|#LOG:EXITBS:START] 2020-10-12T06:14:00
Hi ,MaLd0n
Pls advice for full DSDT patched , the system must be  boot  by OC ,I extract SendMe  but the system use Clover.
The OC for my laptop still not running (didn't boot from OC must  be read  more info).
"if you need a full solution with one full DSDT patched, extract one SendMe with OpenCore running with this app and post here or in DSDT Patch Requests topic, check video first for extract with ioreg "
what ur hardware?
yes. it's true
but many people use incomplete solution and stay happy ;)
what error u have with opencore?
6 hours ago, IUTniun said:
Hi MaLd0N
use "rebase regions" option in acpi tab
  • Thanks 1
3 hours ago, Sinan YOLÇİ said:
hi @MaLd0n
use it, reboot, extract new sendme
config.plist.zip
