1 hour ago, aproject said:
Upload to googledrive
remove ssdt
is a personal things for ur hardware. u need check
9 minutes ago, Hoai Anh Hoang said:
Hi MaLd0n, please advise if High Sierra can install on Intel 10th i5 10400, Z490 ?
not good idea. u need fake many things for that
  • Thanks 1
Hello, I was wondering if there is a substantial difference in performance using a single DSDT or using SSDTs, Right now I use SSDTs and I thought that now that my laptop works well with them I could use them to create a "clean" DSDT with just the necessary. Is it worth it?
dsdt is a full solution, but ssdt work good too, not complete, but is good
perfomance is same if u have a good power management via ssdt or dsdt
Thank you! How can I check if my energy management is good? Is there any way to know? And just one ask more, when starting there is a message that says "ignoring kextcache invocation from early boot" that lasts a few seconds, is it normal?
Edited by Marck00
1 hour ago, Quoc Thai Le said:
Hi MaLd0n
use it, reboot and extract new
config.plist.zip
Hi, I create new zip file!
3 hours ago, Quoc Thai Le said:
Thank for your help, battery and sleep worki g. But kext itlw intel not start to use. What is wrong?
try
DSDT.01.zip
run this app one time
https://www.olarila.com/topic/10296-olarila-repair-app/
10 hours ago, tomqsher said:
Here is my sendme files
this dsdt is full patched
3 hours ago, Nghia Trong said:
hi @MaLd0n can you help to patch DSDT ..
post a full dump
