@Guillep84 barspace dont wake? u need check what wifi u have
barspace dont wake, only button power.
The wifi card is ar928x.
In Catalina I installed Atheros Installer for 10.14 and 10.15.app and the kext AtherosWiFiInjector.kext.zip.
But it won't let me install Atheros Installer for 10.14 and 10.15.app, "touch: / system / library / extensions: Read-only file system".
Change in config.plist, nvram csr-active-config to FF0F0000 but still the same.
All in big sur beta 6
On 9/9/2020 at 9:29 PM, lukakeiton said:
You need to extract it with OpenCore or windows, then you have to disassembly it. Then patch it and assembly again. For your specs, DSDT is not needed. If you are interested on Big Sur, take a look on this!
thank you!!!
Olá MaLd0n, mudei para o opencore bootloacer mas ao acessar no sistema tanto o teclado e mouse não funcionam (ambos USB). Vc poderia dar uma olhada na minha pasta EFI para ver o que está errado? Muito obrigado.
X79_Huanan_EFI.zip
10.15.1 NvmeM2 SSD 500 GB X570 Aorus Elite - Ryzen 7 5800X - 32 GB DDR4 3600 MHz - Radeon RX 580 8GB
10.15.7 SSD120 GB GA-EP45T-DS3R - 16 GB DDR3 1600 MHz - GTX 760 2GB.
5 hours ago, cumpadi said:
Olá MaLd0n
Quote
<dict>
                <key>Comment</key>
                <string>Rename EUSB to EH01 (USB)</string>
                <key>Count</key>
                <integer>0</integer>
                <key>Enabled</key>
                <true/>
                <key>Find</key>
                <data>RVVTQg==</data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <key>OemTableId</key>
                <data></data>
                <key>Replace</key>
                <data>RUgwMQ==</data>
                <key>ReplaceMask</key>
                <data></data>
                <key>Skip</key>
                <key>TableLength</key>
                <key>TableSignature</key>
                <data></data>
            </dict>
            <dict>
                <key>Comment</key>
                <string>Rename USBE to EH02 (USB)</string>
                <key>Count</key>
                <key>Enabled</key>
                <true/>
                <key>Find</key>
                <data>VVNCRQ==</data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <data></data>
                <key>Replace</key>
                <data>RUgwMg==</data>
                <data></data>
                <key>Skip</key>
                <data></data>
            </dict>
Hi MaLd0n,
I've migrated my Clover config to Opencore config, but I still one last thing to migrate: I have a modified IOBluetoothFamily.kext (idproduct and idvendor changed in CSRBluetoothhostcontrollerUSBTransport.kext) that loads in /System/Library/Extensions.
How can I make this change in OpenCore?
20 minutes ago, johncool said:
Hi MaLd0n,
u need read OC manualfor check all u need
Hi Sir, would you mind to help to generate DSDT for my hackintosh ?
sleep doesnt work
i'm using Ryzen 5 3600 and Asrock B450M Steel Legend + RX 5700 XT Sapphire pulse
here's my RunMe result https://gofile.io/d/yTFTMy
Edited by Wawan
18 hours ago, olivermota said:
Olá MaLd0n,
13 hours ago, Wawan said:
Hi Sir
21 hours ago, Wawan said:
2 hours ago, DLorents said:
Hi!
what ur hardware?
Oi, sorry!
Gigabyte Z170XP-SLI i5-6600 iGPU, later install some AMD RX videocard, i will try to boot some Clover image for dumping DSDT and maybe you patch this one, but it takes some time. I will send you donations later today, busy morning...
Biggest question for now, Clover or OpenCore, because i use real iCloud account and dont want to be banned from Apple, Clover shows the real motherboard to MacOS, OpenCore didnt, and the second problem, then dual-boot Win10 and MacOS, then OpenCore shows Apple motherboard to Win10, how about drivers compatibility in Win?
Clover
a good start with this folder
https://tinyurl.com/ttu8wyt
after install extract sendme for we start a fine tune
11 hours ago, aproject said:
Lenovo S540 14iml i7 10510u
config.plist.zip
