On 9/8/2020 at 4:49 PM, MaLd0n said:
this way is just for installation. after that need start a fine tune
i did installation fine, the problem after installation it stuck if boot in normal mood but boot without problems in safe mode
Edited by maldini237
reproduce this problem and post one photo
On 9/10/2020 at 12:50 AM, lukakeiton said:
I took a look to your DSDT, it is not patched at all (DSDT is full solution unless bios update). So, you are using SSDTs or Clover config, but I don't use Clover for years. I suggest you if my configuration works for you, use it! Change serial number and add the kexts you need.
Hello, I'm still using your configuration (change the serial and add my kexts) since it is impossible for me with my DSDT.
The DSDT was generated by MaLd0n in this link and it works fine with clover:
https://www.olarila.com/topic/923-dsdt-patch-requests/page/528/?tab=comments#comment-91319
Then I modify it to show the battery:
https://www.olarila.com/topic/5673-guide-laptop-battery-indicator-the-dsdt-patching-horror/page/11/?tab=comments#comment-103422
Some questions:
- Could you install big sur?
- When I finish loading macos catalina, before the password, the laptop screen turns off, I have to press the power button to turn on the screen, how can I solve it?
I cleaned up the entire boot and relaunched RunMe:
http://s000.tinyupload.com/index.php?file_id=06296672587219584671
Thank you.
if u use opencore need patch again and after that work in clover and opencore
Just now, Guillep84 said:
Some questions:
- It is a future proyect. I am on others now.
- Did you add -wegnoegpu in boot args?
As @MaLd0n said, you need to patch it again. If you are going to use opencore, i suggest you use ssdt.
AMD Ryzen 9 3900X
ASUS ROG STRIX X570-E GAMING
Sapphire Nitro+ Radeon RX 590 8GB
CORSAIR Vengeance LPX 32GB DDR4 3600Mhz
-wegnoegpu
Yes and also removed it and it had no effect
Ok, I'm going to try to generate the ssdt by following:
post one full dump here
1 hour ago, brasileirojr said:
Hey
first try with minimal kexts, only lilu and virtualsmc with no plugins
I did this and now there is an error:
How do I solve it?
  • smcGetKeyInfo Error: Received error 0x84 when getting key info for ALRV
  • smcReadKey Error: Received error 0x84 when getting key info for MSLD
  • smcReadKey Error: Received error 0x84 when getting key info for ALV0
3 hours ago, Guillep84 said:
Hi MaLd0n
u need extract with opencore running
u can ignore this error. the problem is other. or sata or usb
2 minutes ago, brasileirojr said:
It gets stuck on this error
prepare one good folder with catalina with full dsdt patches, the really good folder and after that try big sur
20 minutes ago, Guillep84 said:
Hi, I'm sorry, I didn't know.
remove xosi acpi patch rename, reboot and extract new
25 minutes ago, Guillep84 said:
Ok, removed, rebooted and run RunMe
ur dsdt have many patches
Hello,
DSDT is working properly, thank you very much.
I am trying to configure everything:
- I still have the problem that when I turn it on the screen turns off, I have to press the power button to turn it on, I have the intel HD4000 and nvidia 630m.
- The wifi does not detect it, the icon appears but it does not find any, if I put the injection kext it does not boot.
- I don't get the battery.
For the rest, everything ok.
I leave my config.plist in case you see anything.
Thank you.
config.zip
