Problems with audio on Lenovo L340-15IRH
Hi Guys,
I have Catalina 10.15.5 (19F101) installed on my Lenovo L340-15IRH, all is working great apart from my audio. Sometimes it works and other times it doesn't, what I mean by 'it doesn't' is that it doesn't get detected. At the moment it's working but I know If I need to restart my laptop, the audio will stop working and won't even be detected. When it does work, Hackintool reports it as the attached (Audio.zip) I have also attached a copy of my config.plist
I would be very grateful if someone would be able to help me out
Thanks in advance
Audio.zip config_plist.zip
use alcdelay=500 bootarg
follow here too
  • Thanks 1
I can't thank you enough, this has now resolved the problem
Edited by aide199
