so i already have a working virtual box catalina, but i want to image the olarila drive. can i basically create an image off my external copy , then rename it to vdmk or vhd then mount it as attached storage to my existing vm and choose it as the primary boot drive?
i have not seen any software so far to image the afps drive yet. (other than disk utility)
this is doing what carbon copy cloner does.  what i am wanting to do is create a disk file itself and make a vmdk to attach to virtualbox. i think i can do it via disk utility via image from drive and save to desktop and rename.   i tried as dvd/cdr but did not work
i ended up using this to make a catalina image for kvm/qemu.. it is not bad.
https://computingforgeeks.com/how-to-run-macos-on-kvm-qemu/
I will see if it will update to big sur when the final version comes out.
I may go back to the mac os ; but right now it boot in sleep mode each time, i think have to use my external install to boot it. It did not do it until i tried enabling sleep.
Do you have any ideas?
On 6/27/2020 at 11:53 AM, jackfrost4u said:
thanks
is there a way to reverse this thing, other than restoring a back up?
it did not start until i ran that .com powermangement thing.  after that it starts off not awake on boot. to fix i have to use my external install
u try in ur ssd? native install or VM?
csm is disable?
oh. that was on the ssd. the vm is fine. . the sleep issue is for the install i did on my internal ssd. after i ran that power management thing , it always boots to not awake.  i then use my back up i made to then boot it up. ( but on its own it will not boot)  I have to check for CSM. it is already in the boot config.
with amd gpu disable csm ever
i will have to check. but it was fine before i ran that power management thing.   i think it is easier to have a VM because you can just copy it and save it some place. if any issues just bring it back.
in this case is easy. intel
in ur case is amd, is hard xD
On 7/26/2020 at 6:35 PM, jackfrost4u said:
oh.
how are things? are you ready for big sur?  I started using ryzentosh again today. i had to boot it off the external drive but fine so far.
some people report sucess others no
some people, report sleep fine in big sur
i had csm enabled in the bios.  it is now disabled . i will let you know if that worked.
Still same thing. it says wake failure; but boots fine via the external drive. then i eject the external.
  i even copied the efi folder from the external and did not work.
uploaded the files here-  https://filebin.net/2uwp8e108csw0873
