On 6/25/2020 at 12:32 PM, jackfrost4u said:
ok. so update went fine. i will let it run some , then update my external boot drive i use when i run into trouble.  it actually made the HDR on my display work better now.
for sleep this person has these settings. do you know if they will work with the plist on ryzen? pic attached. the ones in yellow arrows are the ones he said we needed.  the ones in yellow boxes he did not say but can i use them?
here is the video-
sleep items on plist.zip
try this .command. reboot and test
45 minutes ago, jackfrost4u said:
it did not work
if dont work, i think don't have solution in this case :shock:
i think so too. i tried the youtube one and same thing. did not work.
bad
amd don't have native support, sleep and some usb things in some cases don't work
15 hours ago, MaLd0n said:
bad
oh ok thanks.. do you have any virtualbox images for catalina yet?
Catalina no
ye. i need update all. many work xD
no problem.. :)  i may got back to linux host and put this in virtual box.trying to play with restoring my install to 2nd disc in virtual box.
no more macos?
Good xD
check if work
https://www.tweaking4all.com/cd-dvd-blu-ray-disc-burning/burning-for-macosx/convert-dmg-to-iso/
olarila images is .dmg renamed to .raw
rename .raw to .dmg
