1 hour ago, MaLd0n said:
thanks. yeah. i lost my sound. i will update with that to XX.  bluetooth is on without dongle and toggles on /off. i will play with the radeon kext.
config.plist.zip. attached is my config plist. i do not have that nvram listing. config.plist.zip.  i will probably leave this version of clover and not mess with that or the kext once i get sound going. i have sound via my monitor. i may reboot again and see if it comes back.
sent you my EFI folder. -  http://s000.tinyupload.com/?file_id=08293550299594899362
and my latest run me -  http://s000.tinyupload.com/?file_id=04820790549551049870
2 hours ago, MaLd0n said:
so with this one bluetooth toggle works, the amd power gadget works , i can see my fans now. no sound though. i will try to put the realtek kext back in. i saw that it is not in there.
RealtekRTL8111.kext.zip
4 hours ago, MaLd0n said:
the latest EFI you sent does not have the NVRAM part in the plist in it to change the alcid=XX.. i see also that the realtek one is for ethernet.  should i look for a sound kext?
applealc don't work in ur case?
https://www.olarila.com/topic/6074-guide-easy-audio-solution-with-applealc-clover-and-opencore/
7 hours ago, MaLd0n said:
not sure. your first patch with applealc worked fined it is any change after where it does not work.  I may just stick to the first patch. sound is more important than the fan control and bluetooth. is open core better than clover? maybe i should try that?
here is the very first patch with applealc sound works, but not bluetooth. http://s000.tinyupload.com/index.php?file_id=43824103482461657211
can you fix that one so the amd gadget works and sound?
I looked at that link. i think the problem is there is no boot argument for the alc= XX.. when i looked at in xcode and did not see it. i see now the nvram entry is for open core, the other for clover. i will check the plist again.  the good thing is my original install that works i keep on external drive so i use that to boot into the internal one for flip the EFI folder back to work.
sound alc1220.zip attached sound if you can fix for new efi please and that amd gadget works too if you can. the latest one you sent bluetooth toggle good, amd gadget good, just no sound.
plist and layouts.zip. ok . i pulled it up on xcode for the latest  EFI you sent yesterday. it has alcid =1. so do i just go thought and try each layout number to see if that works? also i noticed you have on the same line  -v npci=0x2000 alcid=1,  should i move the -v npci=0x2000 to its own line?
sorry to spam you, so check this out. I went to the very first patch you did for the one that sound works but not bluetooth and the plist there only. -v npci=0x2000. there is no alc but there is a alc kext and sound works. i will try removed the alc =1 and see what happens too.
to sum up everything above. the first patch that worked does not have an entry for boot with alc .. but has the alc kext and sound works. i will try that.  the two patches after boot but no sound with alc=1 and after a few reboots start to have kernel panic.  not sure why but will try with no alc=1. or try different alc numbers for the layout resources folder.
so my latest update today is . it boots with the last EFI you sent. bluetooth toggle. amd gadget working. no sound but will play with maybe using vooda hda, or apple patcher hda. my codec is Realtek® ALC1220-VB codec .
still not sure why the first patch works with no alc entry on the plist. just the kext files. i may try those two kext from the first run.
u can extract one sendme with audio work?
you mean you want me to send you the one that is working with audio? i can zip the EFI folder from the first patch. but bluetooth does not work on the first patch and neither does the amd gadget
i am doing a carbon copy cloner now while i have it at this state, so if i mess it up i can restore it. that way i can play with getting the codec to work.  i will send a run me after the back up is done. it will be with everything working except sound. i will mess with sleep later.
ye
send me both with audio work and ur final folder
2 hours ago, jackfrost4u said:
 wow.. so after all that. I used multi-beast for catalina and installed the voodoohda kext and that took care of it . now i will work on sleep mode.
PLZ. DONT USE IT.
just need add layout id for ur audio codec
try this folder
https://filebin.net/mh2t8dxtw831stpw/EFI_FULL.zip?t=tadr23o9
10 hours ago, jackfrost4u said:
ok. let me check it out.
so that did not work. i tried 1, 3, 5, 7 ,11 and 99 .
the voodoohda kext works immediately. i am going to try and get sleep working. i will make another ccc back up first.
i will let you know if i get sleep working.
ok
16 hours ago, MaLd0n said:
ok
right now wanting to enjoy it some before having to fix something. lol.    do you recommend doing any updates? the osx updates for catalina?
u can ;)
ok. so update went fine. i will let it run some , then update my external boot drive i use when i run into trouble.  it actually made the HDR on my display work better now.
