Hi, I use an old server on socket 1366. To boot Catalina I have to use AppleMCEReporterDisabler.kext.
The problem is that it is not always loaded first and the pc goes into kernel panic.
The question is if there is a way in Clover to establish a kext load order, or if you recommend putting the kext in Library / Extensions or in System / Library / Extensions
no
just paste kexts in folder
post one photo in kp screen
