Hi,
First of all, Thank you for make the best Osx86 ISO ever and ever. I have been using Olarila ISO since High Sierra Mojave with no issue at all.
Yesterday, I decided upgrade to Catalina 10.5.5 everything work smoothly except two things.
1. Bluetooth not discover any devices. Below is the screenshot.
I used to connect my Magic Mouse 2 (white), Magic Mouse 2 (Black), Magic Keyboard, AirPod Pro AirPod 2 with when on Mojave.
After fresh install  with Olaria Catalima 10.15.5.raw none of these are not working anymore.
I've check about mac it found bluetooth. However I'm not sure need to install specific kext or not
My motherboard : Gigabyte H370 AORUS GAMING 3 WIFI  https://www.gigabyte.com/us/Motherboard/H370-AORUS-GAMING-3-WIFI-rev-10/sp#sp
2. After Wake from sleep mode Display enter to HDR Mode.
My Monitor LG-34UK550 4K which support HDR mode https://www.lg.com/us/monitors/lg-32UK550-B-4k-uhd-led-monitor
First boot into RGB mode normally. However it force to HDR Mode every single time when awake from sleep
GPU = MSI RX 580 ARMOR 8G OC
Connect GPU to Monitor via Displayport
Even I already checked force RGB Mode still enter HDR Mode
My Hackintosh setup
CPU : I5 9400F
RAM : Consair 16 GB
Motherboard : Gigabyte H370 AORUS GAMING 3 WIFI  https://www.gigabyte.com/us/Motherboard/H370-AORUS-GAMING-3-WIFI-rev-10/sp#sp
GPU   MSI RX 580 ARMOR 8G OC
Monitor :  LG-34UK550 4K https://www.lg.com/us/monitors/lg-32UK550-B-4k-uhd-led-monitor
I copy original EFI Folder from Olaria Catalima 10.15.5.raw in to my EFI Boot Drive.
Also attached  config.plist for your reference
Kext from original EFI Folder too only add AppleALC.kext (v 1.5) to enable on board sound
Result from RunMe  https://we.tl/t-Wxn6gecnKL
Thank you in advance
config.plist.zip
Edited by oroooat
enjoy
