Hi everyone, it has been a long time i made pc or notebooks for install mac os but with the new version of catalina 10.15.5 or mojave 10.14.6 i see on install we must be connected over the net??? but after connected another error can not continue install because files can not be downloaded is there a fix for that?????
thanks
Asus Vivobook X512DA Ventura 13.5 (ventura works like a charm)
Lenovo ideapad Z710 on sequoia 15.7
Desktop: Asus Z97-C|CPU intel i7 4770K|Nvidia GT 720 2GB|Sequoia 15.6.1| OC 1.0.6
Iphone 14 128GB ios 26
it ok it was just a date problem
k
just back date
no luck still says need internet connexion is there away to add kexts for my wifi under windows system??? does not have any notebook or pc under mac os anymore?
u use last Olarila Images, i updated some days ago
yes the 10.15.5 image
ok but i reupload 10.15.5
ok thank you i will redownload
ok
spacer.pnganother error with the new image ?
image can not use to install macos
Edited by moishiteru
wrong image
Open terminal in installation and run it
date 01011010 2016
still the same error i don't understand? can you give a good link for the image??
i don't understand have installed mac os mojave 10.4.5 boot on it and change date until today reboot, boot on catalina 10.5.5 and now im installing mac os  really weird problem?
all image is tested and work fine
create ur personal
thanks for help
thanks for DSDT patch Mald0n
need help again for audio i see the tutorial audio but no luck
conexant 20752 codec as line inside info.plist inside AppleALC kext but I think not activated
please help
thanks
see efi folder
http://www.mediafire.com/file/ks9zvopbgmy7lkr/EFI.zip/file
yes I see this tutorial but I want to understand one thing .xml files must be copied too???? where???
no, just number with alcid=3 for example
ok have tested some option but still not have sound.... have install voodoo kexts and works but does not really like voodoo....
thanks anyway
no
