Hi all, If anyone can help me with this problem it would be greatly appreciated.
I'm running 10.7.3 on an Asus P8P67 Evo board with an i7 2600k cpu. everything is working great except i can't get C/P states to work. my bootloader is chimera 1.8 and i have a custom DSDT and SSDT, and patched AICPUPM.kext. My LPC device ID is already in AppleLPC.kext and AppleLPC is loading (checked with kextstat). I get this in the kernel.log:
ACPI_SMC_PlatformPlugin::pushCPU_CSTData - _CST evaluation failed
ACPI_SMC_PlatformPlugin::registerLPCDriver - WARNING - LPC device initialization failed: C-state power management not initialized
and this in bdmesg
Read HFS+ file: [hd(0,2)/Extra/DSDT.aml] 35744 bytes.
Read HFS+ file: [hd(0,2)/Extra/SSDT.aml] 2829 bytes.
ACPI table not found: SSDT-1.aml
FADT: Restart Fix applied!
FADT: Using custom DSDT!
ACPI CPUs not found: C-States not generated !!!
ACPI CPUs not found: P-States not generated !!!
RSDT: Added 1 SSDT table(s)
Added 1 SSDT table(s) into XSDT
checking with MSRDumper i get 2 states: 16 and 34 (no turbo, which is set to manual 43 in bios)
Any ideas what i should try to at least get turbo working?
Thanks!
If your custom SSDT has P and C states, you don't need to enable the "generate states" options. If you want to use them, add scope _PR to your DSDT with processors definition.
By the messages in your log I guess your SSDT.aml doesn't have C states.
thanks for the reply. i added the processor definitions to my DSDT and that worked, but caused a kernel panic because of mismatched P states in the SSDT. i deleted the SSDT and booted ok with this:
ACPI table not found: SSDT.aml
Found ACPI CPU: CPU0
Found ACPI CPU: CPU1
Found ACPI CPU: CPU2
Found ACPI CPU: CPU3
Found ACPI CPU: CPU4
Found ACPI CPU: CPU5
Found ACPI CPU: CPU6
Found ACPI CPU: CPU7
SSDT with CPU C-States generated successfully
P-States: min 0x10, max 0x0
but i'm still only getting 2 states, and these error messages in the kernel log:
ACPI_SMC_CtrlLoop::loadStepperContext - pmCPUControl (pmioctlPStateContext_t) failed, result = 0x16
Did you take those definitions from your original SSDT?
Did you enable GeneratePStates too?
i got the processor definitions and my SSDT from this thread: http://www.insanelymac.com/forum/index.php?showtopic=253642
i assumed they would be the same as mine since they're for an i7 2600k also. I compared them to the SSDT i extracted from my system and they look the same.
I removed everything from the scope _PR section of my DSDT except the processor definitions and got rid of the ACPI_SMC_PlatformPlugin errors, but i still have this error.
I removed the GenerateXStates options from my boot.plist and put the SSDT back in /Extra and have 5 working Pstates now: 16 35 36 37 and 38.
Maybe this is the best i can hope for?
Get the definitions from your original SSDT, it depends on the motherboard (BIOS), not on CPU.
Thanks again for the reply. Can you tell me if this is right?
This is the scope _PR from my DSDT:
    Scope (_PR)
       Processor (CPU0, 0x01, 0x00000410, 0x06) {}
       Processor (CPU1, 0x02, 0x00000410, 0x06) {}
       Processor (CPU2, 0x03, 0x00000410, 0x06) {}
       Processor (CPU3, 0x04, 0x00000410, 0x06) {}
       Processor (CPU4, 0x05, 0x00000410, 0x06) {}
       Processor (CPU5, 0x06, 0x00000410, 0x06) {}
       Processor (CPU6, 0x07, 0x00000410, 0x06) {}
       Processor (CPU7, 0x08, 0x00000410, 0x06) {}
If I use DSDTSE and extract the SSDT, i get this:
* Intel ACPI Component Architecture
* AML Disassembler version 20091214
* Disassembly of ./SSDT.aml, Mon Mar  5 15:20:02 2012
* Original Table Header:
*     Signature        "SSDT"
*     Length           0x000001D6 (470)
*     Revision         0x01
*     Checksum         0x10
*     OEM ID           "AMICPU"
*     OEM Table ID     "PROC"
*     OEM Revision     0x00000001 (1)
*     Compiler ID      "MSFT"
*     Compiler Version 0x03000001 (50331649)
DefinitionBlock ("./SSDT.aml", "SSDT", 1, "AMICPU", "PROC", 0x00000001)
   External (\_PR_.OSC_, IntObj)
   External (\_PR_.PDC_, MethodObj)    // 1 Arguments
   Scope (\_PR)
       Processor (P000, 0x01, 0x00000410, 0x06)
           Method (_PDC, 1, NotSerialized)
               \_PR.PDC (Arg0)
           Method (_OSC, 4, NotSerialized)
               Return (\_PR.OSC)
               Arg0
               Arg1
               Arg2
               Arg3
       Processor (P001, 0x02, 0x00000410, 0x06)
               \_PR.PDC (Arg0)
               Return (\_PR.OSC)
               Arg0
               Arg1
               Arg2
               Arg3
       Processor (P002, 0x03, 0x00000410, 0x06)
               \_PR.PDC (Arg0)
               Return (\_PR.OSC)
               Arg0
               Arg1
               Arg2
               Arg3
       Processor (P003, 0x04, 0x00000410, 0x06)
               \_PR.PDC (Arg0)
               Return (\_PR.OSC)
               Arg0
               Arg1
               Arg2
               Arg3
       Processor (P004, 0x05, 0x00000410, 0x06)
               \_PR.PDC (Arg0)
               Return (\_PR.OSC)
               Arg0
               Arg1
               Arg2
               Arg3
       Processor (P005, 0x06, 0x00000410, 0x06)
               \_PR.PDC (Arg0)
               Return (\_PR.OSC)
               Arg0
               Arg1
               Arg2
               Arg3
       Processor (P006, 0x07, 0x00000410, 0x06)
               \_PR.PDC (Arg0)
               Return (\_PR.OSC)
               Arg0
               Arg1
               Arg2
               Arg3
       Processor (P007, 0x08, 0x00000410, 0x06)
               \_PR.PDC (Arg0)
               Return (\_PR.OSC)
               Arg0
               Arg1
               Arg2
               Arg3
The SSDT that i'm actually using is this:
* AML Disassembler version 20110316-64 [Mar 16 2011]
* Copyright (c) 2000 - 2011 Intel Corporation
* Disassembly of ssdt_pr.aml, Mon Mar 28 06:05:00 2011
*     Signature        "SSDT"
*     Length           0x00000156 (342)
*     Revision         0x01
*     Checksum         0x67
*     OEM ID           "APPLE "
*     OEM Table ID     "CpuPm"
*     OEM Revision     0x00001000 (1)
*     Compiler ID      "INTL"
*     Compiler Version 0x20110316 (537985814)
DefinitionBlock ("ssdt_pr.aml", "SSDT", 1, "APPLE ", "CpuPm", 0x00001000)
   External (\_PR.CPU0, DeviceObj)
   External (\_PR.CPU1, DeviceObj)
   External (\_PR.CPU2, DeviceObj)
   External (\_PR.CPU3, DeviceObj)
   External (\_PR.CPU4, DeviceObj)
   External (\_PR.CPU5, DeviceObj)
   External (\_PR.CPU6, DeviceObj)
   External (\_PR.CPU7, DeviceObj)
   Scope (_PR)
       Scope (\_PR.CPU0)
           Name (_PSS, Package (0x10) // Not required anymore (because APSS is used instead)?
               Package (0x06) { 3401, 0x00017318, 0x000A, 0x000A, 0x2600, 0x2600 },
               Package (0x06) { 3400, 0x00017318, 0x000A, 0x000A, 0x2200, 0x2200 },
               Package (0x06) { 3300, 0x00016B6F, 0x000A, 0x000A, 0x2100, 0x2100 },
               Package (0x06) { 3200, 0x000163C6, 0x000A, 0x000A, 0x2000, 0x2000 },
               Package (0x06) { 3100, 0x000154BA, 0x000A, 0x000A, 0x1F00, 0x1F00 },
               Package (0x06) { 3000, 0x000145F5, 0x000A, 0x000A, 0x1E00, 0x1E00 },
               Package (0x06) { 2900, 0x00013776, 0x000A, 0x000A, 0x1D00, 0x1D00 },
               Package (0x06) { 2800, 0x0001293C, 0x000A, 0x000A, 0x1C00, 0x1C00 },
               Package (0x06) { 2700, 0x00011B47, 0x000A, 0x000A, 0x1B00, 0x1B00 },
               Package (0x06) { 2600, 0x00010D96, 0x000A, 0x000A, 0x1A00, 0x1A00 },
               Package (0x06) { 2500, 0x00010028, 0x000A, 0x000A, 0x1900, 0x1900 },
               Package (0x06) { 2400, 0x0000F2FE, 0x000A, 0x000A, 0x1800, 0x1800 },
               Package (0x06) { 2300, 0x0000E616, 0x000A, 0x000A, 0x1700, 0x1700 },
               Package (0x06) { 2200, 0x0000D971, 0x000A, 0x000A, 0x1600, 0x1600 },
               Package (0x06) { 2100, 0x0000CD0C, 0x000A, 0x000A, 0x1500, 0x1500 },
               Package (0x06) { 1600, 0x000092D9, 0x000A, 0x000A, 0x1000, 0x1000 }
           Name (APSN, 0x04) // Number of turbo states (see Intel Datasheet for your CPU).
           Name (APSS, Package (0x14) // This is the PerformanceStateArray data
               Package (0x06) { 3800, 0x00017318, 0x000A, 0x000A, 0x2600, 0x2600 }, // Fourth Turbo State.
               Package (0x06) { 3700, 0x00017318, 0x000A, 0x000A, 0x2500, 0x2500 }, // Third Turbo State.
               Package (0x06) { 3600, 0x00017318, 0x000A, 0x000A, 0x2400, 0x2400 }, // Second Turbo State.
               Package (0x06) { 3500, 0x00017318, 0x000A, 0x000A, 0x2300, 0x2300 }, // First Turbo State.
               Package (0x06) { 3400, 0x00017318, 0x000A, 0x000A, 0x2200, 0x2200 }, // Maximum non-turbo frequency.
               Package (0x06) { 2000, 0x0000C0E9, 0x000A, 0x000A, 0x1400, 0x1400 },
               Package (0x06) { 1600, 0x000092D9, 0x000A, 0x000A, 0x1000, 0x1000 }  // Lowest Clock frequency.
           Method (ACST, 0, NotSerialized)
               Return (Package (0x06)
                   One,
                   0x04,
                   Package (0x04)
                       ResourceTemplate ()
                           Register (FFixedHW,
                               0x01,               // Bit Width
                               0x02,               // Bit Offset
                               0x0000000000000000, // Address
                               0x01,               // Access Size
                       One,
                       0x03,
                       0x03E8
                   Package (0x04)
                       ResourceTemplate ()
                           Register (FFixedHW,
                               0x01,               // Bit Width
                               0x02,               // Bit Offset
                               0x0000000000000010, // Address
                               0x03,               // Access Size
                       0x03,
                       0xCD,
                       0x01F4
                   Package (0x04)
                       ResourceTemplate ()
                           Register (FFixedHW,
                               0x01,               // Bit Width
                               0x02,               // Bit Offset
                               0x0000000000000020, // Address
                       0x06,
                       0xF5,
                       0x015E
                   Package (0x04)
                       ResourceTemplate ()
                           Register (FFixedHW,
                               0x01,               // Bit Width
                               0x02,               // Bit Offset
                               0x0000000000000030, // Address
                       0x07,
                       0xF5,
                       0xC8
           Name (_PPC, Zero)
           Name (_PCT, Package (0x02)
               ResourceTemplate ()
                   Register (FFixedHW,
                       0x40,               // Bit Width
                       0x00,               // Bit Offset
                       0x0000000000000199, // Address
               ResourceTemplate ()
                   Register (FFixedHW,
                       0x10,               // Bit Width
                       0x00,               // Bit Offset
                       0x0000000000000198, // Address
           Name (_PTC, Package (0x02)
               ResourceTemplate ()
                   Register (FFixedHW,
                       0x00,               // Bit Width
                       0x00,               // Bit Offset
               ResourceTemplate ()
                   Register (FFixedHW,
                       0x00,               // Bit Width
                       0x00,               // Bit Offset
           Name (_PSD, Package (0x05) { 0x05, Zero, Zero, 0xFC, 0x08 })
           Method (_CST, 0, NotSerialized)
               Return (Package (0x04)
                   0x03,
                   Package (0x04)
                       ResourceTemplate ()
                           Register (FFixedHW,
                               0x00,               // Bit Width
                               0x00,               // Bit Offset
                       One,
                       One,
                       0x03E8
                   Package (0x04)
                       ResourceTemplate ()
                           Register (SystemIO,
                               0x08,               // Bit Width
                               0x00,               // Bit Offset
                               0x0000000000000414, // Address
                       0x02,
                       0x50,
                       0x01F4
                   Package (0x04)
                       ResourceTemplate ()
                           Register (SystemIO,
                               0x08,               // Bit Width
                               0x00,               // Bit Offset
                               0x0000000000000415, // Address
                       0x03,
                       0x68,
                       0x015E
           Name (_TPC, Zero)
           Name (_TSS, Package (0x08)
               Package (0x05) { 0x64, 0x03E8, Zero, Zero, Zero },
               Package (0x05) { 0x58, 0x036B, Zero, 0x1E, Zero },
               Package (0x05) { 0x4B, 0x02EE, Zero, 0x1C, Zero },
               Package (0x05) { 0x3F, 0x0271, Zero, 0x1A, Zero },
               Package (0x05) { 0x32, 0x01F4, Zero, 0x18, Zero },
               Package (0x05) { 0x26, 0x0177, Zero, 0x16, Zero },
               Package (0x05) { 0x19,   0xFA, Zero, 0x14, Zero },
               Package (0x05) { 0x0D,   0x7D, Zero, 0x12, Zero }
       Scope (\_PR.CPU1)
           Method (APSS, 0, NotSerialized)
               Return (\_PR.CPU0.APSS)
               Return (\_PR.CPU0._CST)
           Method (_PCT, 0, NotSerialized)
               Return (\_PR.CPU0._PCT)
           Method (_PPC, 0, NotSerialized)
               Return (\_PR.CPU0._PPC)
           Method (_PTC, 0, NotSerialized)
               Return (\_PR.CPU0._PTC)
           Method (_PSD, 0, NotSerialized)
               Return (\_PR.CPU0._PSD)
           Method (_PSS, 0, NotSerialized)
           Method (_TPC, 0, NotSerialized)
               Return (\_PR.CPU0._TPC)
           Method (_TSS, 0, NotSerialized)
               Return (\_PR.CPU0._TSS)
       Scope (\_PR.CPU2)
               Return (\_PR.CPU0._PSS)
       Scope (\_PR.CPU3)
       Scope (\_PR.CPU4)
       Scope (\_PR.CPU5)
       Scope (\_PR.CPU6)
       Scope (\_PR.CPU7)
also i just noticed that something i did while working on this has caused sleep to no longer work right. when i sleep the computer, the screen goes black but the fans stay on, and it won't wake back up.
...frustrating ;)
It's correct, you just used CPU0 instead of P000 (and so on), but I think it's not a problem.
Try using this plist in /System/Library/Extensions/IOPlatformPluginFamily.kext/Contents/PlugIns/ACPI_SMC_PlatformPlugin.kext/Contents/Resources http://Olarila.com/forum/download/file.php?id=1491
i'm pretty sure i had done that, but i did it again just in case. i figured out why my sleep stopped working. deleting the method _CST from my DSDT made the errors go away, but broke sleep. any suggestions how i should modify it?
        Method (CST, 0, NotSerialized)
           If (LNotEqual (And (PDCV, 0x0200), 0x0200))
               If (LEqual (NCST, 0x02))
                   Store (One, NCST)
           If (LEqual (NCST, Zero))
               Return (C1ST)
           If (LEqual (NCST, One))
               Return (CIST)
               Return (CMST)
           Return (C1ST)
I would let Chameleon generate P and C states.
Yeah, i would rather have them generated automatically. i'm working toward that now. got rid of SSDT.aml and put GenerateCStates and GeneratePStates back into org.chameleon.boot.plist.
what i'm trying to figure out now is why sleep stops working when i remove the Method CST section from Scope _PR in my DSDT, and how to put it back in without causing ACPI_SMC_PlatformPlugin errors.
Have you tried leaving only CPU definitions in scope _PR in DSDT? You can remove all the rest, _CST and _PSS will be generated in SSDT by Chameleon.
yeah, when i only have the processor definitions speedstep works but sleep doesn't work right. with the Method CST block in there sleep works, but i get ACPI_SMC_PlatformPlugin errors and only 2 speeds, 16 and 38.
Hi all! please i have a same message on boot screen: :(
acpi_smc_platformplugin start waitforservice resourcematching appleintelcpupowermanagement timed out, and i don't know if the used patches are working for my system config,
Please if there is something to do to DSDT
here is my patched DSDT.aml, and original acpi Aida 64: dsdt and ssdt from windows7
Mobo: Asus P5Q-E vBios: 2101
CPU: Intel Core 2 Quad Q9650
GPU: PowerColor ATI HD AX4870 512M
RAM: 2x1 Go Kingston 2x2 Go A-DATA
acpi_dsdt.bin.zip
acpi_ssdt.bin.zip
