Hello,
I have been trying for many days to make hardware acceleration (OpenCL, Metal) works with my Gigabyte AMD RX 5500 XT. When ever I open the program that needed it, my Mac crashes. I can't even run GeekBenmark on both OpenCL and Metal. Now I guess I need a patch. Could you help me please, I had to forced restart my Mac so so so many times....
Thank you.
MacOS 10.15.5
Motherboard: ASUS H81M-D Plus (Already set BIOS settings)
CPU: Intel Core i7-4790k
RAM: 16GB (8x2)
GPU: Gigabyte AMD RX 5500 XT OC 4 GB
Send Me.zip: http://s000.tinyupload.com/?file_id=99059679308065028367
Edited by elvinXCs
whatevergreen inject properties in last version
first try with only intelhd enable and whatevergreen last version
Hello,
I enabled iGPU in BIOS
Added shikigva=80 boot flag
Enabled Intel Inject
I rebooted the machine, it's not working.
So I now enter the key and value found in that post (Haswell) and restart, It's still not working :(
post ur config.plist here
extract ioreg
is loaded. check
freeze stay there?
