Hello...I discover Olarila las week and it was a blessing since i was trying another distros ans even Opencore Vanilla without sucess.
my computer is:
  • Intel core I7-5820k
  • Mobo Gigabyte x99 G1 Gaming Wi-fi
  • 16 GB RAM (4x4GB)
  • Kingston Savage SSD240 SATA for Hackingtosh
  • BPX 480GB NVMe for Windows
  • Kingston A400 480GB for games :)
  • nVidia Geforce GTX 1080 Founders Edition
  • Olarila High Sierra
”Problem” is that on cold boot, the Hackintosh is booting with the “Display 7MB”...I install the latest nVidia Web Drivers using Nvidia.update command from Olarila tools and I can switch to GTX1080 after rebooting with success...all warm boots keeps the nVidia web Driver without issues.
I try the nvda_drv=1 flag in clover, the NvidiaWeb=True in config.plist and some clover fixes for the lack of writable NVRam in x99....everything was futile.
it is not a big problem (after all, just the switch in graphics and reboot ans voila) but I want to know if there any solution for this matter
post one full dump
Extract tables with F4 key in Clover boot screen, boot into system and run this app
Good news...I install your EFI folder and now seems to be working properly, I reboot warm and cold to double check several times and everytime the Nvidia web driver works as expected
may I ask what was the problem/solution to my particular problem? Just to learn :)
thanks in advance
full dsdt patch with correct config.plist
hello how his problem is very similar to mine, I ask:
use a gtx1070 with high sierra, everything is installed correctly, webdrive ok, cuda OK.
more on rendering the card does not trigger gpu acceleration,
collers are silent.
I've tried everything I can't get the GPU acceleration to work.
any tips?
Arquivo Comprimido.zip
activate intel quick sync via IGPU
