Lion 10.7.2 on GA 945GCM-S2C vga not working properly
i have got almost everything working, got the 1440x900 resolution and also added the EFI String but i cant play any video
i tried many kexts, it's been 2 months still couldnt get the vga working properly
my vga--
Intel 950
0x8086
0x2772
0x0002
please need some help
thank you
It will work only in 32 bit (arch=i386).
You need EFI string or DSDT patch http://Olarila.com/forum/viewtopic.php?f=7&t=56
You can use DSDT Editor to apply http://Olarila.com/forum/viewtopic.php?f=19&t=634
thank you for the reply,
I'm running in 32bit
i have applied the EFI string and DSDT patches.
i think i need correct drivers for GMA950 0x2772
i tried many kext versions and combinations of versions but only these two give me better graphics
AppleIntelGMA950.kext v6.0.0
AppleIntelIntegratedFrameBuffer.kext v4.2.0
i have attached some info of my computer
thanks
just got my vga working correctly with all the features after applying DSDT patches
thanks Cassio for the reply
these are the patches i used
DTGP patch
# Add method DTGP to the main block, it's used by other patches
into method label DTGP remove_entry;
into definitionblock code_regex . insert
begin
Method (DTGP, 5, NotSerialized)\n
{\n
   If (LEqual (Arg0, Buffer (0x10)\n
           {\n
               /* 0000 */    0xC6, 0xB7, 0xB5, 0xA0, 0x18, 0x13, 0x1C, 0x44, \n
               /* 0008 */    0xB0, 0xC9, 0xFE, 0x69, 0x5E, 0xAF, 0x94, 0x9B\n
           }))\n
   {\n
       If (LEqual (Arg1, One))\n
       {\n
           If (LEqual (Arg2, Zero))\n
           {\n
               Store (Buffer (One)\n
                   {\n
                       0x03\n
                   }, Arg4)\n
               Return (One)\n
           }\n
           If (LEqual (Arg2, One))\n
           {\n
               Return (One)\n
           }\n
       }\n
   }\n
       {\n
           0x00\n
       }, Arg4)\n
   Return (Zero)\n
end
GMA950 desktop
# Insert device PEGP into device PCI0
into device name_adr 0x00020000 parent_label PCI0 remove_entry;
into device label PCI0 insert
begin
Device (PEGP)\n
{\n
   Name (_ADR, 0x00020000)\n
   Device (GFX0)\n
   {\n
       Name (_ADR, Zero)\n
       {\n
           Store (Package (0x06)\n
               {\n
                   "device_type", \n
                   Buffer (0x08)\n
                   {\n
                       "display"\n
                   }, \n
                   "model", \n
                   Buffer (0x07)\n
                   {\n
                       "GMA950"\n
                   }, \n
                   "built-in", \n
                   Buffer (One)\n
                   {\n
                       0x01\n
                   }\n
               }, Local0)\n
           Return (Local0)\n
       }\n
   }\n
end
