Hello Everyone
Please Help Me?
Im Want Get Full DSDT Patch for  olarila catalina to install olarila catalina. Please Help Me
i can install olarila catalina See On this Topic,
What i do??
Edited by fariwar farsian
Extract tables with F4 key in Clover boot screen, files generated in Clover/Acpi/origin, post here
Hello
 im in clover boot screen press f4 and is hanging im restart my pc and Files in the folder you say and i again restart my pc and in installation screen in log again hang on  ROM Features returned : 4228899190
My problem was not solved?
Please Help Me
15 minutes ago, fariwar farsian said:
Hello
Please Help Me
I guess MaLd0n is telling you to press F4 on Clover boot screen (the one where you choose the partition to boot) and then go to EFI partition and copy the files on Clover/Acpi/origin folder in a zip. Then, post them here.
You have to access EFI partition from a working operative system. Google should help :smoke:
Edited by pepe21
What DO mean About copy file in efi and where i put .zip file??
Do you know what an EFI partrition is?
13 minutes ago, fariwar farsian said:
Yes I kmow
Ok, then you have to access to EFI partition. When you are in EFI partition, you will find an EFI folder. Inside EFI folder you have more folders, one of them is CLOVER.
Inside the CLOVER folder you must find another folder called ACPI. Inside the ACPI folder you find the origin folder.
You have to create a .zip of that origin folder and upload to here (via mediafire or any filehosting).
Paste the link here so MaLd0n can access to the files inside the origin folder.
Bigger image if you need (https://ibb.co/37LbbdH)
Edited by pepe21
i can share zip file with google drive??
Here Link of origin.zip File: https://drive.google.com/file/d/1eMiyixFId3Q5V64Cvxjnvmj-BpdYynm8/view?usp=sharing im shareing with google drive.
if google is not work here is mediafire link: http://www.mediafire.com/file/lzmqyy0ty98lsuc/origin.zip/file .
Thank You For Your Helping pepe21
Now What I Do MaLd0n??
Please answer up topic?? please im very very very need olarila catalina?
 here is origin.zip File mediafire link: http://www.mediafire.com/file/lzmqyy0ty98lsuc/origin.zip/file
clover/acpi/patched
