Hi Admin!
My device ASUS TP501UB:
i5 6200U, 8GB Ram, SSD Kingston 120GB, DW1820A (08PK)
My device one Ram 4GB onboard I add 4GB  (ram Samsung DDR3L 1600MHz) in slot = 8GB ram
Before add ram Samsung my device sleep wake normal
After add ram my device wake lag glitch on battery (plugin no glitch)
I inject EDID, repatch Framebuffer. All not working
Plese help me I'm not good English Thank you very much!
My clover and picture in link:
https://drive.google.com/drive/folders/1UJ2Sc7iTk3h9ayYt5tCdDiwe1kJMdaTn?usp=sharing
try other video patch
yes
Extract tables with F4 key in Clover boot screen, boot into system and run this app
impossible solve it with this folder
use Olarila folder, is a good start with clean config
im use but not working
im uninstall ram devices sleep wake normal
im install ram (change samsung to kingston) my device glitch after wake on sleep
u need use olarila folder, apply a video patch and embedded controller rename
Im try but not fix proplem
im no change clover and macos
if i remove ram my device sleep wake very great
else install ram my device glitch when use battery (plugin adapter sleep/wake very great my proplem when only baterry)
