greenpieleon Posted May 27, 2020 Posted May 27, 2020 (edited) Hello everyone, i succeeded install Catalina 10.15.4 on my HP EliteBook 840 G1, i5 4300u with ihd4400. Everything works fine except the battery, i tried to patch that and not worked. My friend help me and it still not worked. I already tried RehabMan post install in github, but after that i cannot boot to system, then i tried to reinstall and repatch again but still the battery not worked and system information said battery not installed. Can anyone here help me to patch dsdt for my battery? I attach my EFI link below.. Thankyou https://drive.google.com/file/d/1jVTvDLmXxFoy8k1sZFqjy08C-shvYHxN/view?usp=sharing here is the screenshoot from system information https://imgur.com/du3lQ7G https://imgur.com/jzQgtRO Edited May 27, 2020 by greenpieleon
Administrators MaLd0n Posted May 27, 2020 Administrators Posted May 27, 2020 u need use a correct folder, don't use folder from Olarila images is just for installation https://www.olarila.com/topic/5676-folders-for-all-chipsets-clover-and-opencore/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
greenpieleon Posted May 27, 2020 Author Posted May 27, 2020 ok i will try to change my old EFI folder with new EFI folder based on my chipset, and copy any files in my old efi folder to new efi folder, is that right? so what about my battery status? can you help me to fix that please?
Administrators MaLd0n Posted May 27, 2020 Administrators Posted May 27, 2020 use Olarila folder and enable EC0 to EC https://tinyurl.com/ujc7989 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
greenpieleon Posted May 28, 2020 Author Posted May 28, 2020 (edited) i already tried to replace my old EFI folder with Olarila EFI folder and try to enable EC0 to EC but after that i cannot boot to the system, i attach the verbose log and at the end, it show attempting system restart, what should i do? help me please.. thankyou https://imgur.com/m2zClh2 Edited May 28, 2020 by greenpieleon
