Hello,
After several attempts keeping only the NVMe SSD for Catalina (I disconnected the Sata HDDs and the NVMe for Windows),
I get a block:
capture image in joined file
Here is my configuration:
CM: ASUS Prime Z390-A Gaming Mainboard Sockel 1151
CPU: intel I9 9900k + Corsair Hydro Series H115i RGB Platinum
RAM: 64 GB Corsair Vengeance LPX 32GB (2x16GB) DDR4 3200MHz C16 XMP 2.0
SSD1 for windows: 2 TB Samsung MZ-V7S2T0BW 970 EVO Plus NVMe M.2
SSD2 for Catalina: 2 TB Samsung MZ-V7S2T0BW 970 EVO Plus NVMe M.2
HDD: 1.5 TB + 2 TB
Box: Corsair iCUE 465X RGB Tempered Glass ATX Medium-Tower Gaming Box
Gaphic card: Asus Dual RX580 O8G Gaming (Radeon, PCIe 3.0, 8GB DDR5 Speicher, HDMI, DisplayPort, DVI).
Can you help me move forward?
I thank you in advance
Chris
IMG_2271.rar
Edited by Ch35000
2 SSD 1 for windows  and  for Catalina : 2 TB Samsung MZ-V7S2T0BW 970 EVO Plus NVMe M.2
Extract tables with F4 key in Clover boot screen, files generated in Clover/Acpi/origin, post here
sorry to be so long, but i could no longer access my USB key. But here is the file
origin.rar
use Olarila folder serie 100/200/300
in wich folder of the usb key i have to copy dsdt.aml ?
Edited by Ch35000
FOLDER serie 100/200/300
put my dsdt into clover/acpi/patched
Thank you for your help, i really appreciate. i have succeeded to installl Catalina on my computer.  I'm arrived at point "7- Copy Olarila EFI folder to EFI partition"
I'm sorry but i have one more question :
I have tried to copy kexts from "CHIPSET SERIES 10, 20 and 30" , i have dowloaded before, but i can't paste these kexts into the EFI folder of my SSD mac os.
is there something like security permissions to succeed paste ?
IMG_2274.rar
Edited by Ch35000
no, into efi partition no
i have reinstalled Catalina and succeeded to copy Kexts into EFI/CLOVER/Kexts/Other and DSDT.aml into ACPI/patched.
i have installed clover with success but it doesn't appears in Applications, I tried to reinstall Clover but every times it failed,
Could you help me ?
Edited by Ch35000
How do you make part 7 : a-Video patch and b- Embedded Controller Device ?
is it possible to fix Clover ?
Edited by Ch35000
u just need a video patch if use internal graphics, the other things all inside my dsdt
i have a Gaphic card: Asus Dual RX580 O8G Gaming (Radeon, PCIe 3.0, 8GB DDR5, HDMI, DisplayPort, DVI).
And about Clover how i can fix it?
Edited by Ch35000
just use DP output for legacy mobo
i'm sorry, i'm a very rooky, what is DP ?
thank you for your patience
how i can do that ?
dp = display port ;)
Thanks a lot, i' m really sorry to bother you, but it is normal with very old people like me (65 last month)?
i have found clover
Edited by Ch35000
I have succeeded to install Catalina  all is perfect except there is no sound,
Could you help me for this last worry
My Z390 has Realtek ALCS 1220A audio codec,
DPCImanager detect it, but no sound
Archive.zip
