Salute ,
my Laptop is Toshiba Satellite C50-A570
i have already windows 10 pro installed .. and i have installed Mac Os Catalina on the same hard drive .. i got it installed perfectly but here are the issues
1- i can't boot into clover from the HDD , i tried alot of solutions like using EasyUEFI to create a new boot direction to boot from CLOVERX64 but it failed .. i also tried to rename bootmgfw.efi to bootmgfw-orig.efi but i got black screen with no boot .. i tried to replace bootmgfw.efi with Cloverx64 also renaming it to be bootmgfw.efi and it worked but i can only boot into Mac , i can't see Windows .. if i didn't take a backup from windows efi previously i would have to reinstall windows again lol
2- sound problem my friend tried to fix it with voodoo but we failed , my multimedia is IDT92HD95
3- Battery Problem i can't see it on the bar and can't even make it show up
4- Bluetooth can't be shut down , it is Qualcomm Atheros AR3012 Bluetooth 4.0
5- Brightness ... can't change anything about it
BUT my main problem as i mentioned before is the boot .. i just want to be able to boot without my usb i tried to send boot , clover from usb efi to my computer's efi and didn't work so i'll be very thankful if someone helped me to boot without usb .. my 2,3,4 and 5th problems if you only know the right solution i'll be thankful but if you don't know it's okay i'll fix them later if i could only solve problem of boot
