Can't delete EFI folder and EFI-backups folder under root folder for Catalina system
Hello ,
There are two folders (one is EFI folder ,other is EFI-Backups) under root folder ,System will generate this two folders when i install new version clover for update clover boot on SSD.
I want delete these two folder , but i find out that i haven't right to delete them . i try type command " rm -rf  EFI " and " sudo mount -uw / " under terminal ,but system notice me some wrong info about Permission denied .
It is forbidden to delete this two folders  (one is EFI folder ,other is EFI-Backups under root folder ), isn't it ?
by the way
i had been set disable for system integrity protection  .
Please help me and give some suggestions.
Thank you .
delete_info.jpg.zip need be delete folder under root folder.jpg.zip
Edited by kai wang
add some info
