Dell 5491 : Trackpand can't work and can't adjust screen birightness
Hello ,
below is detail hardware configure for laptop dell 5491.
  • Bios: 1.11.1
  • CPU: i5-8300H @2.3G
  • Memory: 8G DDR4 2666MHZ
  • Mainboard: DELL 0NFNN4 (CM246 Chipsets)
  • SSD: Toshiba 256G NVME (primary)
  • HDD: SATA ST1000LM049 (second)
  • Sound: Realtek ALC256
  • Lan: Intel I219LM7
  • Wireless/Bluetooth: Qualcomm QCA61X4A 802.11AC
  • TrackPad Hardware ID : ACPI\VEN_DELL&DEV_0818 (I2C HID )
I has been completely install Catalina 10.15.4 on my laptop .
exit blow two problems:
  1. Trackpand can't work
  2. can't adjust screen birightness
Attachment is my EFI file and kexts list .
Please help me and give some suggestions.
Thank you .
config.plist.zip Kexts.jpg.zip touchpad_info_dell5491.png.zip
first u need use a correct config, folder above is very bad
15 hours ago, MaLd0n said:
correct config,
Hello ,
What means is this words " older above is very bad" , This words 's means is kexts files are very mussy under kexts folder ,is't it?
i want download "NOTEBOOKS CHIPSET SERIES SKYLAKE+ " via your site  for CLOVER FOLDERS  but i can't access https://tinyurl.com/vpecysf .
By the way
i has been download  CLOVER.NOTEBOOKS.SERIES.CHIPSET.zip this file  under  download  menu
CLOVER.NOTEBOOKS.SERIES.CHIPSET.zip is Notebooks chipset series skylake+  ,isn't it ?
yes, enable ecdv to ec patch and apply video patch, reboot and extract new send_me
Hello ,
i put this new dsdt.aml file into acpi folder, then restart laptop .
  1. Trackpad is still can't work .
  2. adjust screen brightness function is working now .Good
extract on ioreg
https://olarila.com/files/Utils/IORegistryExplorer.app.zip
Hello ,
There are four options under main menu via run IORegistryExplorer.app.
1,IOService
2,IODeviceTree
3,IOPower
4,IOUSB
Which option is i should select ?
