mozbius Posted May 3, 2020 Posted May 3, 2020 I am following Olariaâs instruction to install OSX 10.13.6 released 2020 but I am unable to see my SATA hard drive during the install process (in diskutil). My motherboard is an Asus P6 T Deluxe v2 (x58 chipset Legacy motherboard with no UEFI support). Problem remains no matter what setting I use (IDE, RAID or AHCI). Note: My hard drive was detected no problem with Niresh 10.13 USB release. Can somebody help me or suggest a way to make my harddrive appear during the install of MacOS Olarila 10.13.6?Â
Administrators MaLd0n Posted May 3, 2020 Administrators Posted May 3, 2020 ich10 need a patch try it AHCIPortInjector.kext.zip  -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
mozbius Posted May 4, 2020 Author Posted May 4, 2020 (edited) 5 hours ago, MaLd0n said: ich10 need a patch try it AHCIPortInjector.kext.zip 4.15 kB · 4 downloads  Thank you MaLd0n  for your help. Unfortunately that didn't work. With that kext on the Orila USB I get a crash with the non entry logo  before I even get to lay eyes on the installer itself. FYI 1: I use "Set Nvidia to VESA" because I have a GTX 260 video card (without that I get a reboot of the computer). FYI 2: I have copied the kext to the EFI partition of the USB in EFI/CLOVER/kexts/Other at first (that resulted in a crash) then I used EasyKext Pro to install the kext into Library/Extensions (but the crash is still happening) with AHCI or IDE or RAID in BIOS.   Edited May 4, 2020 by mozbius missing text
Administrators MaLd0n Posted May 4, 2020 Administrators Posted May 4, 2020 use ahci mode and with this folder https://filebin.net/9r8ryid63bf049oz/EFI.zip?t=ah0r4y4t -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
mozbius Posted May 4, 2020 Author Posted May 4, 2020 1 hour ago, MaLd0n said: use ahci mode and with this folder https://filebin.net/9r8ryid63bf049oz/EFI.zip?t=ah0r4y4t I have taken the ZIP then did a REPLACE (should I have done a MERGE instead?) and the result is the same.  OBSERVATIONS (if it can help) : I did face an identical situation with the previous 10.13.6 Olarila package that was provided here and was able to work around it (in IDE, RAID & AHCI) by using the zip that is associated to Tech Labs' video (unfortunately that doesn't work with the 2020 package).   Â
mozbius Posted May 4, 2020 Author Posted May 4, 2020 2 hours ago, MaLd0n said: use ahci mode and with this folder https://filebin.net/9r8ryid63bf049oz/EFI.zip?t=ah0r4y4t Should I use the AHCIPortInjector.kext in this EFI ?
Administrators MaLd0n Posted May 4, 2020 Administrators Posted May 4, 2020 the problem is about usb, try all ports -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
mozbius Posted May 4, 2020 Author Posted May 4, 2020 3 hours ago, MaLd0n said: the problem is about usb, try all ports Somehow I am not confident that the problem is the USB to be honest because then how would you explain that the older packaged Olarila 10.13.6 and Niresh 10.13 go through the install every single time without fail on that same USB key and same USB port? That being said I will do my due diligence and leave no stone unturned and will test all the USB ports on the PC with 4 different USB keys with : *Olarila Stock *Olarila AHCI Injected  *Olarila EFI replaced *Olarila 2020 Stock *Olarila 2020 AHCI Injected *Olarila 2020 EFI replaced And then come back here with my results. Obviously itâs going to take some time but hey it is Social distancing time! Lol.
shabaa Posted May 4, 2020 Posted May 4, 2020 (edited) Leave no stone unturned is a good idea. I had a similar problem with my first Hackintosh when snow leopard came out but perseverance finally came through and the problem was resolved.  I know you addressed your video card issue by making it vesa but that isnât a great solution and the 200 series nividia cards arenât really compatible. Get a compliant card that will work with the later OS versions. Edited May 4, 2020 by shabaa Z77 Build= Quad Boot Win 10, Win 7, Mojave, Kali Linux (learning). 2x NVME drives, 1X Samsung EVO SSD, 1X 16GB USB 3.0 (Kali) 1X 1TB WD storage drive, GTX770, 16GB Gskill ARES, Work in progress1: P35-DS3R, Xeon 3360 @3.2GHz. 8GB ddr2 800, Tri-Boot system. Work in progress2: G31M-ES2L, Q9650 @ 3.2GHz. 4GB ddr2 800, Tri-Boot system Waiting on case for next build..... Â
Administrators MaLd0n Posted May 4, 2020 Administrators Posted May 4, 2020 7 hours ago, mozbius said: Somehow I am not confident that the problem is the USB to be honest because then how would you explain that the older packaged Olarila 10.13.6 and Niresh 10.13 go through the install every single time without fail on that same USB key and same USB port? Extract tables with F4 key in Clover boot screen, files generated in Clover/Acpi/origin, post here -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
