[Battery Patch Working] Lenovo IdeaPad 310-15IKB [Tested on Catalina]
Thanks to MaLd0n sir who is helping people as mine .
Actually I am newbie in Hackintosh , I was just looking for battery patch for my Lenovo-Ideapad-310-15IKB
And found patch for Ideapad-100 (Originally Created by Superwolf123 and some fixes by Rehabman sir ) .
When I compare Integers greater than 8bits with my Lenovo-Ideapad-310-15IKB
, these are similar . I have to remove 1 method fix just. I am using  VirtualSMC.kext with SMCBatteryManager.kext
Here is the patch.
If this post should edit/modify please do that @MaLd0n
Thanks.
battery_Lenovo-Ideapad-310-15IKB.txt.zip
Edited by Zahid Islam
On 7/19/2020 at 6:57 PM, gurudayal singh khasa said:
@Zahid Islam sir , I have same device as yours. Can you please share your efi files with me? It will be a great help. I tried many times. Pls help. You can share some google drive etc links of the files if sharing at olarila is not allowed.
I am using triple boot . So Delete unnecessary files, also delete DSDT.aml from ACPI/patched directory .
https://drive.google.com/file/d/1j_MTycCPSfGAaT-hwbzobpDmKA5ACA7D/view?usp=sharing
Plase EFI FILE
Laptop:
- Merk : Lenovo ideapad 310-15IKB
- Prosesor : DualCore Intel Core i5-7200U, 3100 MHz
- iGPU : Intel(R) HD Graphics 620 (1 GB)
- dGPU (Jika ada) :
- RAM : 1x 4GB DDR4 1064.4 MHz
- Adaptor Audio : Conexant CX20751/2 @ Intel Sunrise Point-LP PCH - Definisi Tinggi
- Adaptor Audio : Adaptor Audio Intel Kaby Lake HDMI @ Intel Sunrise Point-LP PCH - Tinggi
- Trackpad : Elan 1200 I2C
- Penyimpanan : ADTA SSD SU650
- LAN Nirkabel : Intel Dual Band Wireless-AC 3165 AC HMC WiFi Adapter PCI
- Ethernet : Realtek RTL8168/8111 PCI-E Gigabit Ethernet Adapter (PHY: Realtek RTL8111)
Edited by Majelis Dzikir Nuridzati
