Hello everyone . sorry but i don't write very good english i would like to install Catalina on pc i downloaded image but from this error my computer:
ASUSTeK COMPUTER INC. TUF X299 MARK 2 (LGA 2066 R4)
Intel Core i7-7800X CPU @ 3.50GHz
NVIDIA GeForce GTX 760
Realtek High Definition Audio
Ram 35 GB
if anyone can kindly help me to install the catalina system  thanks
screen.rar
i am not an expert i apologize and soon i will make a donation with paypal but i don't understand what i have to do. I downloaded your Catalina image after I installed it on a 16GB pendrive balenaEtcher I start from a pendrive and from this photo error I have to change something in the bios?
if image dont work, try with this efi folder
https://tinyurl.com/r3npswk
I downloaded your folder but where should I put it if I can't install the system
efi partition in ur usb stick
if u have a mac use clover configurator
if u have windows check google
ok ... but is it better to first partition the pendrive or first to write catalina image and then create a partition and then copy your folder?
use patch APIC in acpi tab
no idea what happen
