i compiled it
try ;)
I'm using this system now seriously. And i realized that if i connect the mouse via usb I have huge lags, freezes, skips while I move around with the mouse. If I use it over bluetooth (usb dongle) it never freeze but there seems a problem with moving on bluetooth too. Though it's clearly better on bluetooth. What can be the cause behind this?
extract one send_me
http://s000.tinyupload.com/index.php?file_id=32965709476567973498
Here it is. Usb mouses impossible to use for now. I checked with 3 mouses. Bluetooth mouses has a little issues but clearly way better than usb.
Can you help me with "about this Mac" reboot too?
Thanks in advance MaLd0n.
config looks good
generate one usb injector with hackintool and check if solve
I attached a zip file which includes Hackintool Screen Shot after I've done my work. I have no idea what USR1 and USR2 are. So I remained them untouched. And Hackintool generated some ssdt files but I did not use them. I just used usbports.kext and it seems it worked. But I'm not sure.
Edit: I think the problem is gone. I did not experience any lags/skips for 25 minutes.
Usb.zip
Edited by aarslan419
good
u need only usbports.kext
I found really weird and interesting issue. I think it was not related with usb. If I open AppStore and if an app has a video preview playing at background the system freezes constantly. Maybe I might misunderstood just because I had AppStore opened in the background. I can replicate the issue by simply opening AppStore and go to Arcade tab. Because there are lots of app previews on this tab. It's not a mouse issue. Whole system freezes constantly. Do you have any idea?
check monitor for what amount of memory is used
I can't learn it from "Apple Menu-->About this Mac" because it causes reboot as you know.
So i typed system_profiler SPDisplaysDataType  to terminal.
And the response is;
    Intel UHD Graphics 630 (Desktop):
      Chipset Model: Intel UHD Graphics 630 (Desktop)
      Type: GPU
      Bus: Built-In
      Slot: PCI Slot 0
      VRAM (Dynamic, Max): 1536 MB
      Vendor: Intel
      Device ID: 0x3e92
      Revision ID: 0x0002
      Metal: Supported, feature set macOS GPUFamily2 v1
remove SystemProfilerMemoryFixup.kext and check if work
EDIT: After you imply that the problem can be related to gpu, I tried a lot of things and one of them turned out to an interesting situation.
If I boot without using -igfxvesa I can boot
1- with resolution 1080p instead of 4K.
2- Display is recognized as wrong inches.
3- Interestingly not using -igfxvesa solves the "About this Mac" reboot problem ( I can see system info)
4- igpu seems like recognized ( I think because of patch )
5- and on AppStore there is no freezing.
6- mouse skips/lags still there.
use -cdfon
this solved the "about this mac" reboot issue thanks.
19 minutes ago, MaLd0n said:
use -cdfon
i am using usb C to hdmi 2.0 cable to connect my display. HDMI to HDMI was always black screen for me.
-igfxvesa and -cdfon have the completely same results. App store freezing. Mouse skips/lags. No progress there.
I checked apple tv app. Movies don't play. i think it is related with drm but i tried a trailer and that caused same freezes. It is obviously a gpu issue.
