I can't make the touchpad working even with GPIO pinning guide from github. Tried multiple pins but doesn't work (already applied Windows patches)
System Specs
i3 - 7100U
4GB RAM
Windows Precision HID
Cannon Lake-H touchpad (\_SB.PCI0.I2C1.TPD0)  (0x6c APIC Pin)
edit : ioreg doesn't show any IOInterruptSpecifiers anymore but Touchpad still isn't working (Installed Voodooi2C and VoodooHID)
DSDT and RunMe.app https://filebin.net/pbt5idhe2rhgcyq5
Edited by BloodRace
additional info
9 hours ago, BloodRace said:
Still trackpad isn't working :( what could be the problem. If it helps, here's the Intel I2C Controller : pci8086,a161 (Kaby Lake)
check bios if have advanced trackpad option
https://filebin.net/l5h1twut5umsbrfb/EFI.zip?t=4ku0fo7r
Hello All,
Can someone can help me with setting up my touchpad working with gestures on OpenCore? what files I have to provide for someone look into them and tell me what is wrong??
check order kexts in ur config.plist
6 minutes ago, Mati_Waldi said:
it's proper I believe, atached SS
check Olarila folder oc notebook
i fix kext order, now I get output Kexts\VoodooI2C.kext\Contents\PlugIns\VoodooGPIO.kext\Contents\Plugins\VoodooGPI0 is missing for kext VoodooI2C.kext/Contents/PlugIns/VoodooGPIO.kext ()
But I checked Package Content and all is in the place (using newest version 2.4)...
I forgot to mention, renames are made properly ( checked with maciASL).
If I use OC SNapshot, and save it, I get output in LOG file
08:505 07:935 OC: Prelink injection VoodooI2C.kext () - Invalid Parameter
08:608 00:102 OC: Prelink injection VoodooI2CHID.kext () - Invalid Parameter
Edited by Mati_Waldi
you do know that they are supposed to be in certain order like gpis first then input then services and then. only i2c
