Please help me in DSDT patching for Intel HD 3000 Graphics
Hi,
I am facing all those artifacts on my ASUS X53SC Laptop and found that many were able to solve the problem by editing the DSDT by adding the following code:
               Store (Package (0x02)
                       "AAPL00,DualLink",
                       Buffer (0x04)
                           0x01, 0x00, 0x00, 0x00
                   }, Local0)
               Return (Local0)
But the problem is that the DSDT for my system already contains the following method with this code:
Method (_DSM, 4, Serialized)
                   Name (_T_0, Zero)
                   If (LEqual (Arg0, Buffer (0x10)
                               /* 0000 */    0xF8, 0xD8, 0x86, 0xA4, 0xDA, 0x0B, 0x1B, 0x47,
                               /* 0008 */    0xA7, 0x2B, 0x60, 0x42, 0xA6, 0xB5, 0xBE, 0xE0
                       Store (Zero, Local0)
                       Store (ShiftLeft (DerefOf (Index (Arg3, 0x03)), 0x18), Local0)
                       Add (ShiftLeft (DerefOf (Index (Arg3, 0x02)), 0x10), Local0,
                           Local0)
                       Add (ShiftLeft (DerefOf (Index (Arg3, One)), 0x08), Local0,
                           Local0)
                       Add (ShiftLeft (DerefOf (Index (Arg3, Zero)), Zero), Local0,
                           Local0)
                       If (LNotEqual (Arg1, 0x0100))
                           Return (Buffer (0x04)
                               0x02, 0x00, 0x00, 0x80
                       Store ("Optimus _DSM is called ", Debug)
                       While (One)
                           Store (Arg2, _T_0)
                           If (LEqual (_T_0, 0x00))
                               Store ("Optimus _DSM subfunc 0, return 0x04000001 ", Debug)
                                   0x01, 0x00, 0x03, 0x04
                           Else
                               If (LEqual (_T_0, 0x1A))
                                   Store ("Optimus _DSM subfunc 26 ", Debug)
                                   If (And (Local0, One))
                                       ShiftRight (Local0, 0x18, Local2)
                                       If (LEqual (Local2, 0x03))
                                           Store ("Optimus _DSM subfunc 26, OMPR=3", Debug)
                                           Store (0x03, \OMPR)
                                       If (LEqual (Local2, 0x02))
                                           Store (0x02, \OMPR)
                                   If (LEqual (\PO54, Zero))
                                           0x59, 0x00, 0x00, 0x01
                                   Else
                                           0x41, 0x00, 0x00, 0x01
                               Else
                           Break
                   Return (0x00)
Because i am very new to DSDT patching, i am unable to understand where should i incorporate the changes required so that i can make Intel HD 3000 Graphics work smoothly. I even tried some heroic things but then the output was a blank screen. Please help me in editing this _DSM method. My device id is 116.
I would try replacing
                    Return (0x00)
by
                       "AAPL00,DualLink",
                       Buffer (0x04)
                   }, Local0)
               Return (Local0)
Or replace the existing _DSM by the new one, since it looks like to be related to nVidia Optimus, which doesn't work in hackintosh.
Hi Cassio,
Thanks a lot for the suggestion. I see you are almost replying to all the posts here. That's great! People come to this forum for help and they don't return back disappointed. Hats off!
My problem hasn't got resolved. I've tried all different DSM methods i could find, tried replacing the existing one as you recommended, also tried modifying the default one with the extra stuff, but none of them are removing the artifacts on my Laptop. QE/CI is also not working. In the game of Chess, after 2 moves, the game hangs.
So please guide me as to what can i do..
I did go through with the revogirl's blogs to increase the VRAM size and i was able to do so. But still bad luck. No QE/CI. If i play the game of chess, after 2 moves, it's still the same old story of freeze.
After multiple attempts, i have still not succeeded in making the display work 100%. I don't know why DSDT editing of _DSM method is not working for me. The only result i see if i edit the DSDT is a garbage screen. My device id is 116, so the system detects the card only if i set GraphicsEnabler=No and if set to Yes, it will show the card as unknown. Increasing the VRAM also didn't help.
Still those artifacts are haunting me. Everytime i play the game of Chess, it hangs after 2 moves. Someone please help!
This guy was having the same problem and found that the problem is in the LCD, he replaced the display (physically) and the problem is gone http://Olarila.com/forum/viewtopic.php?f=6&t=924 (portuguese)
