rev4turbomonster Posted April 8, 2020 Posted April 8, 2020 Hi All, After some help if someone would be so kind. I have the below system: Asus z390 prime a i9 9900kf 64gb 3000mhz corsair vengeance ram sapphire nitro+ rx5700 XT nvme for windows 10 ssd for Mac OS catalina I have everything running perfectly apart from sleep using opencore. iMessage iCloud App Store FaceTime are all working spot on. The only thing that isn't working is sleep. When I was using clover this worked without fail on the old rx580 that I had but I could not get DisplayPort working on the new card so switched to opencore which boots more quickly and looks to be a great option and also gives me working displayport. However when I sleep the system it instantly wakes and when I put sudo pmset -g into terminal I get the following response 1 (sleep prevented by UserEventAgent, sharingd) But nothing is turned on for sharing. All of the guides advise against using sleep so I am struggling to find what the settings should be and would like to get it working as I always use it and find it works for me. Any help would be massively appreciated Thanks Matt
Administrators MaLd0n Posted April 8, 2020 Administrators Posted April 8, 2020 https://www.olarila.com/files/Utils/RunMe.app.ziphttps://www.youtube.com/watch?v=k9wmIfGLe3A -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
