Hi, just to spend my time in this period, i decide to upgrade my Yosemite hackintosh to el capitan. In osx installer  popup this worning: osx could not be installer on your computer. No packages were eligible for install. Any ideas?
Thank you
i'm sorry, just few reserch and i found how to escape from the "no packages were eligible" problem. only setting the date on terminal and installation went to the end.
but now i have another problem, kernel panic cpu 2 caller.  my mobo is asus p5e3  8Gb ram xeon q 6600 gpu: gt610 2Gb.
i use clover 5070.
Thank you
yes
use Olarila images
Olarila images dont use fakesmc sensors
sorry, i don't understand, i donwoaded olarila images, follow the guide to make a usb el capitan installer. On  first reboot, after installation, on clover i had that kernel panic. You told me olarila images don't use fakesmc sensor but in the usb efi i found fakesmc as you can see in the screenshot attached. where i'm wrong?
Schermata 2020-04-04 alle 13.05.33.png.7z
send me this efi folder
maybe i found the cause. running g parted on my ssd i found that in a strange way i had an old efi that utility disk don't erase during installation. i erase everything with gparted and now i have el capitan. But Fakesmc .kext is inside the images.
i will try to send to you.
Now i'm in trouble with ethernet ahahhah.
4 hours ago, sailman66 said:
here we are. my sendme .7z file in attach
check what ur lan card, use dpci manager
