[Help] Random freezes in Mojave 10.14.6 (HP Z440, RX 580)
I just bought the old workstation HP Z440 few weeks ago and tried to install Mojave 10.14.6 and Dual Boot with Windows 10. But after a week ago, while I am using the Hackintosh 1-3 hours, or even shorter time , the PC is freezing, I cannot move the mouse or type anything. I must to press the Power Off button to restart the machine. And it will happen again next time. Does anyone have any idea about that problem. This issue happens only on macOS and has never happened when running Windows 10.
Specs:
  • Mainboard: HP Workstation Z440
  • Chipset C612
  • 8 slots DDR4 ECC REG - 8 SAS/SATA HDD/SSD
  • CPU: Intel® Xeon® Processor E5-2673v3 12 Core 24 Threads 2.4Ghz Turbo 3.1Ghz 30M Cache
  • RAM: 16 GB DDR4 ECC REG 2133Mhz
  • Storage: Samsung SSD Evo 860 250 GB + HDD Western Digital Blue 1TB 3.5" SATA 3
  • GPU: XFX AMD Radeon RX 580 8G DDR5 256Bit
Kexts:
  • AirportBrcmFixup
  • RTCMemoryFixup
  • AtherosE2200Ethernet
  • ealtekRTL8111
  • AtherosWiFiInjector
  • USBInjectAll
  • CPUFriend
  • VoodooHDA
  • FakeSMC
  • VoodooTSCSync
  • IntelMausi
  • WhateverGreen
  • Lilu
  • XHCI-unsupported
I don't have any idea that it caused from the hardware or Clover Configuration
I would really appreciate any helps from anyone!
Edited by Phien
use iMacPro1,1 smbios
Sorry!  I am newbie. How can i set up that things?
Edited by Phien
use clover configurator
yah, I already set those things,but this morning I used in 4 hours then it was freezing and cannot touch anything. Is that the issue from Bios from HP Z440 ?
extract one dump
11 hours ago, Phien said:
Dear
Dear Madlon,
It was still freezing. So annoyed while I was listening music or call Video on Zoom.
Do you have any ideas ?
