Greetings..I'm using the appropriate X79 Chipset, however upon USB Boot, it freezes at this screen. Any assistance would be greatly appreciated. Thank you!
Asus X79Deluxe
Intel i7 4930K
RX580 Sapphire
10.15 Catalina
IMG_5463.jpeg.zip
Extract tables with F4 key in Clover boot screen, files generated in Clover/Acpi/origin, post here
5 minutes ago, ssprod said:
Thank you Maldon..I can't get the USB Install to post. It freezes at the image I posted.
just press f4 and files generated into clover/acpi/origin inside efi in ur usb stick
37 minutes ago, ssprod said:
Thanks Maldon!
EFI.zip
3 minutes ago, ssprod said:
Thanks for you patience. I'm freezing here.
try block usbinjectall
Tried numerous bios settings, including bios update. Still freezes at the ethernet connection. I've blocked usb, and ethernet, even SuperI/O. Same freeze.
14 hours ago, ssprod said:
Good morning! Tried with Mojave (same EFI) with this result. IMG_5467.zip
some kexts with inject problems, InjectKexts=Yes?
1 hour ago, ssprod said:
Hello
one more shot
EFI 02.zip
This is why you are a wizard.. it finally booted to a USB Installation screen. I will keep you updated. Thank you so very much!
5 hours ago, ssprod said:
All is good post installation except that only the front 2 USB3 ports are working. None of the rear's are active. Any help with this would be much appreciated. Thanks!
use it and block USBInjectall
check if work
None of the blue USB ports are functional and USB3.0 is not listed in System Information. The 2 black ports on the front and 2 black ports in the rear (upper) are functional. I also tried with disabling AsMedia USB3 controller in bios, no change. Thanks for your efforts here, Maldon. Appreciate it.
u need try a genericxhci kext
GenericUSBXHCI.x79.zip
but usb don't appears in sytem profiler, but work
