I'm experiencing a static noise sound when my Hackintosh is running.
It's not persistent, It occurs for example when I scroll a webpage on Safari or most of the time when the cpu frequency goes up. You can find the noise in the attachments.
My audio setup is a Breeze (tpa3116) amp with 2 JVC speakers.
https://filebin.net/8rvhhhkd3gwttk6t/Send_me_Edoardos-iMac.fritz.box.zip?t=jr1bi2x3
Thanks,
Edoardo C.
Hackintosh static noise.zip
Edited by EdoardoConti
added the sound recorded
bad quality from pc output, use bluetooth and no more issues
What do u mean with "use bluetooth" ? Connect speakers with BT? That's not a optimal solution overall ...
