Preferences OK - Third party prefs won't load ! help plz
Hi,
I got catalina 10.15.3 quite easily and it works flawlessly, Hibernation + sleep mode are still to be tested.
Thanks for that ;))
I installed Logitech Control center with all necessary permissions in security and privacy and it appears in preferences but I never got it to start.
Error : "couldn't load logitech control center window"
I get the same exact message when I try to start SteerMouse from Preferences after installation.
I repaired permissions, cleared caches, removed internet attributes ... No luck yet
Any help would be appreciated.
Edited by temis01
UPDATE to 10.15.4 beta and check if work
catalina bêta 10.15.4 (19E258a) installed in 15 min
Capture-d-e-cran-2020-03-10-a-19-54-39.p
Logitech Control Center installs fine but useless yet piece of shyte... does not detect MX revolution
Will investigate and try other USB port ...
No luck with Logitech Control Center 3.9.11 supposedly compatible with Catalina, but unable to recognize it's own babies !!
SteerMouse 5.4.4 working !
