hello guys i need help, install Catalina 10.15.3 (19D76), everything works except the sleep function, this has a solution? thanks!!
Build
MOTHER: ASUS P8Z77-V
PROCESSOR: INTEL XEON E3 1260L
GRAPHICS: NVIDIA GT 730
BIOS VERSION: 2104 MOD PMPATCH CFG MSR UNLOCK
DSDT patchmatic PJALM for Asus P8Z77-V
SSDT Power Management ssdtPRGen.sh
SSDT-EC
SSDT-UIAC Hackintool
Clover-ioreg.zip
don't use usbinjectall in this case
Thank you! I'm going to try, I'm using usbinjectall because it helps me with the USB 3.1 ASmedia 1042 ports on the back is a hub combined with 2 Asmedia 1042 and 2 USB 2.0 ports (the 2.0 ports always without problems), the 1042 sometimes charges them already sometimes not (usbinjectall helps me to always load them) I am using the Oyen digital drivers for those ports by modifying the info.plis of the kext mXhci to 0x10421b21
Thank you! I'm going to try, I'm using usbinjectall because it helps me with the USB 3.1 ASmedia 1042 ports on the back is a hub combined with 2 Asmedia 1042 3.1 and 2 USB 2.0 ports (the 2.0 ports always without problems), the 1042 sometimes charges them already sometimes not (usbinjectall helps me to always load them) I am using the Oyen digital drivers for those ports by modifying the info.plis on the kext mXHCI to 0x10421b21 and installing in S/L/E
