Brightness problem - Fujitsu LH532 (10.15.3)
Hello guys,
i've installed Catalina 15.3 on my Fujitsu LH532 and i would like some help in order to finish my build.
I'm having a hard time getting brightness to work.  I've tried 2 methods both failed.
1st method  Clover-> Add PNLF & Intel Backlight  - Intel Backlight Max.
2nd method SSDT-PNLF & WEG
I can see slider in syspref but its not working
Working:
Ethernet
USB
Sleep
Graphics Accelaration
Battery
Trackpad
Camera (Disabled for now cause it breaks sleep)
Not working:
Backlight - brightness
Specs
FUJITSU LH532
i7-3632QM
GraphicsIntel HD4000
Thanks in advance for your help.
Hello MaLd0n
I've followed the guide you posted and now I can change brightness with fn+f5/f6 (I was able to do that before with f14+f15). But the problem is that brightness won't change neither from syspref>slider nor  from hotkeys.
I get this behaviour when I use the latest voodoops2controller ( this kext doesn't recognise my ALPS trackpad so I am using it as a mouse)
When I use VoodooPS2Controller-R6RC2.kext (trackpad recognised) when I press fn+f6  I can see brightness icon but it also lowers my volume (fn+f8)
In both cases I can't change brightness
Bellow is my original Methods for Q11 and Q12
Method (_Q11, 0, NotSerialized)  // _Qxx: EC Query
                        Store (0x11, P80H)
                        If (LEqual (^^^GFX0.DD02._DCS (), 0x1D))
                            Return (Zero)
                        Notify (^^^GFX0.DD02, 0x87)
                        Store (One, ^^FJEX.BLLF)
                        Notify (FJEX, 0x80)
                    Method (_Q12, 0, NotSerialized)  // _Qxx: EC Query
                        Store (0x12, P80H)
                            Return (Zero)
                        Notify (^^^GFX0.DD02, 0x86)
                        Notify (FJEX, 0x80)
Edited by skunkone
try this PNLF
into_all device label PNLF remove_entry;
into scope label _SB insert
begin
Device (PNLF)\n
        {\n
            Name (_HID, EisaId ("APP0002"))  // _HID: Hardware ID\n
            Name (_CID, "backlight")  // _CID: Compatible ID\n
            Name (_UID, 0x10)  // _UID: Unique ID\n
            Name (_STA, 0x0B)  // _STA: Status\n
        }\n
end
I added PNLF device into dsdt and removed PNLF-SSDT.aml
Same behaviour. Hotkeys and slider work but brightness stay the same.
One thing that changed is applepanel before it was FT14Txxxx now it is FT16Txxxx.
Also in IORegistryExplorer> PNLF Apple Max brightness = 0x56
shouldn't it be 0x710 for Ivy?
I tried Set Intel backlight options with same result
ye, try with 14 = 0x0E
Name (_UID, 0x0E) // _UID: Unique ID\n
same as before. could it be something in my dsdt or my clover settings? I've been trying for a week now to fix brightness.
Just booted with your EFI. Now it shows the option for automatically adjust brightness under the slider but brightness stay the same. ?
extract new send_me with my folder
:smoke:no idea, check google
