I have a problem with screen brightness  on a Dell 5570.
Although there is a slider in settings it doesn't change brightess at all. Sme thing happens with OpenCore bootloader and Catalina also.
This problem doesn't not exist if I use platform-id 0x59160000.
Thanks in advance.
Y.G. I have deleted kexts/other folder because file is too large to upload.
Send me High-Sierra.zip slider and kexts folder.zip
no idea, go to mojave or catalina, with this folder above i think work
check this maybe?
https://github.com/Mateo1234454545/Dell-5570-hackintosh
some guy also reporting issue after update  to 10.15.3 with brightness
Edited by intommy
Build 1: Intel i5-6600 Skylake, GA-B150m-D3H, 8GB DDR4, ASROCK Radeon RX 590 Phantom Gaming X 8G OC,  512GB - LENSE20512GMSP34MEAT2TA (NVMe) - windows / Patriot Burst 240 Sata macOS Catalina, Fractal Design Meshify C Mini Dark TG, Corsair RM650x, Catalina 10.15.4./ Win10  Build 2: Toshiba Tecra z40-c-11e, Intel Core i5 6200U Skylake, 8GB DDR3, Intel HD Graphics 520, Kingston UV500 240GB (SUV500/240G), BroadCom BCM94360CS2  + 12+6 Pin WIFI wireless card module to NGFF M.2,, Catalina 10.15.4  Build 3: Optiplex 790, Intel Core i3 (2nd Gen) 2120 / 3,3GHz, Intel Q65 Express, 8GB DDR3 (4x2GB), MSI GTX 760 - 2GB, Patriot Burst SSD 120GB, BroadCom BCM94360CS2  + 12+6 Pin WIFI wireless card module to NGFF M.2, Catalina 10.15.4. Build 4: Lenovo L340-15IRH Gaming Laptop - Type 81LK (81LK0034CK), Intel Core i5 9300H (2,40-4,10GHz), 8GB DDR4 2400MHz (1x8), Intel UHD Graphics 630, Catalina 10.15.4 / Windows 10 (Patriot Burst 240GB SATA3 SSD / M.2 PCIe SSD 512GB), DW1820a, atm not work: Wifi 5GHz, only 2,4 and BT.
