Finally have a Catalina all setup! Working great!
There is one issue i need to resolve, and that is setting up a Apple ID that works.
I created one, and used it to create a iCloud Account. That worked!
What does not work is using the Apple ID to sign in. It gives me the "Account Limit Reached" error. Screenshot 2020-02-24 at 13.27.14.png.zip
I need to fix this so that I can download Xcode from the App Store.
From googling this error, it seems that some "Serial Number" gets tracked and clover probably uses the same every time.
Could someone help let me know how to change that?
I assume I can use the Clover Configurator tool. But I am not sure what to change, and how to change it?Screenshot 2020-02-24 at 13.40.27.png.zip
Thanks,
     Rui
smbios tab and generate new full smbios with serials, etc
