Donation with Stripe https://tinyurl.com/2ssnydn6
Donation with BuyMeaCoffee https://tinyurl.com/bvsbpf6e
Donation with BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3
Donation with PicPay @danielnmaldonado
Donation with Mercado Livre https://tinyurl.com/y9evkj5u
1--Download Olarila Image--
https://www.olarila.com/topic/6278-olarila-vanilla-images/
2--Tutorial--
-OpenCore
https://www.olarila.com/topic/15040-opencore-vanilla-guide-2021-folder-for-chipsets-monterey-ready-desktop-and-notebook/
-Clover
https://www.olarila.com/topic/5794-guide-install-macos-with-olarila-image-step-by-step-install-and-post-install-windows-or-mac/
3--EFI Folders for Chipsets--
https://www.olarila.com/topic/5676-folders-for-all-chipsets-clover-and-opencore/
4--DSDT Patch Request--
https://www.olarila.com/forum/17-dsdt-patch-requests/
If you are a donor use a personal room and support!
https://www.olarila.com/forum/84-dsdt-patch-requests/
-Credits and thanks to the old and new people in the community who developed patches, kexts and bootloaders!
  • Thanks 1
10 minutes ago, Sampath007 said:
?? Awesome
:smoke:
hi MaLdOn,  i can't use open core on my dell (broadwell) with catalina apfs, the downloaded folder doesn't work and runme app doesn't work. I send my dsdt that I use with clover if you can check or give suggestions, thanks
dell xps13 9360
core i7
Intel HD620
-ram 8 gb ddr3
-hard disk da 256 gb SDD
5 hours ago, vrondena said:
hi MaLdOn
post one photo in error screen
dear sir,
i wanted to migrate from clover to opencore bootloader. i prepared a USB thumb drive with olarila opencore EFI folder. the problem is when i select Macintosh HD on opencore gui screen, after 2 or 3 second my machine restart again and again.
hardware specs:
asus h97m-e
intel core i5 4440
intel hd graphics 4600
8GB RAM
128GB SATA SSD
Afinal, onde está o guia de instalação usando o OpenCore? Não entendi este tópico... ?‍♂️
SAMSUNG NP300E4C-AD2BR core i3 2328m Intel HD Graphics 3000 (1366x768) 4Gb RAM DDR3 HDD 120Gb Ethernet Realtek RTL8168 Wi-Fi Atheros AR9485 Bluetooth Atheros AR3012
é só vc seguir a ordem no tópico, acabou que esses viraram secundários depois que lancei o Tutorial Install MacOS with Olarila Image, Step by Step, Install and Post Install
Hello MaLd0n
I was able to configure the OpenCore folder and boot from it but I'm still struggling with the PlatformInfo section of the config.plist. After booting and starting up MacOS, when I go to System Information app the system freezes and stop working. I'm doing something wrong for sure configuring the PlatformInfo section in the OpenCore config file. Could  you take a look at my config files in OpenCore and Clover to see if I can have in the OpenCore config file something similar to what I have in the clover config file?
config OpenCore.plist.zip config Clover.plist.zip
check Olarila folders
I am also trying to install Catlina on my Gigabye P55M-UD2 machine
Currently I have Win10, and two old macOS partitions (Snow Leopard and Lion)
I have try to start from usb, but computer gets blocked at the screen to select the language in the installation screen (no mouse or keyboard are working, it seems it is blocked, HDD drive light is ON)
is catalina valid for this mobo? (I have been able to go foward with other tutos, but t the end the HD was nor recognized)
Note: I have tried installing over an old ATA HDD,  and also to current Data HDD. the same issue no matter the HDD installed
regards
Edited by Waldus
yes, but u need use smbios iMac13,2
@MaLd0n, como vai?
Segui tuas dicas e consegui rodar o Catalina de prima. ??
Só estou inseguro com o estado da nvram, usb mapping, com a smbios escolhida e quaisquer outros detalhes que possam comprometer o desempenho ou a estabilidade do ambiente (Z390 M Gaming / i7-9700KF / RX 5500 XT 8GB).
Baixei e rodei o RunMe. Poderia me ajudar?
http://s000.tinyupload.com/index.php?file_id=64214407369791097510
Muito obrigado. Abs.
Edited by fabiodrs
forgot to mention usb map
já deu uma busca no fórum? eu já editei esse arquivo várias vezes de todas as versões de bios
Segui o tópico para "Ga Z390M Gaming / Core i9 9900k / RX590".
Não sei se há tópico mais apropriado, mas foi sucesso. FLAWLESS! Boot rápido, perfeito e ambiente estável. Falta resolver apenas a DRM (Netflix no Safari), isto é, se viável no iMac19,1.
Muito obrigado, Daniel. Abs.
5 hours ago, shimon said:
Why there is no EFI folder for opencore chipset series 6 ? ?
Create one
Hi, I followed your instruction and succeeded to install Mojave on my machine.  The only way I can login is if I use the installation your EFI, config 1 with inject envida driver enabled.
Notebook series 6 efi does not work.  Do appreciate if you could please give me some help.
ThanksSend me rog53sws-MacBook-Pro.zip
