AMD Catalina 10.5.1 - 5700XT fan not spinning
Hi I have succefully install 10.5.1 using olarila's image.
Everything works great !
Only that my MSI Gaming X 5700xt - fan doesn't spin at all, causing the graphic card to be very very hot.
The only instant that i see it spin is during the brief period when i run geekbench metal benchmark.
All other times it doesn't spin.
I also ran Luxmark, it also dosn't spin.
Anyone else have it issue?
Below are my specs:
3900x AMD
Gigabyte X570 Motherboard
MSI Gaming X 5700XT
32GB memory
is common, fan start if temp stay high
run one benchmark and check
