Hello Maldon!  I submitted a Runme.zip file to you a while back and have just now gotten around to trying to apply it.
When I do, it breaks all USB.  The only way that I can access the machine is remoting into it.
I was able to look in ioReg and see that the PCI section did contain data.  If the DSDT is not there, nothing shows in that section.
Can you take a look at my zip file again and see if there is anything that has changed?
Please and thank you.  I did contribute again.
https://drive.google.com/open?id=13QjQQOKGAxq7vYEdtc4EuPfjdShKotXu
PS - This machine is on Mojave since I do have older, 32bit apps/games.
My other Hackintosh runs your DSDT and Catalina and it runs great!
1st Hackintosh... i7-5775c, ASRock Z97 Extreme6, Vega 64 FE
2nd Hackintosh... i5-7600k, ASRock Z270 Extreme4, RX5700
18 minutes ago, onthewall said:
Hello Maldon!
EFI.zip
REMOVE GenericUSBXHCI.kext and FakePCIID.XHCIMux
Any idea why this would kill my bluetooth?  WiFi works fine.  I am using an AzureWave CE-123H.  I have went through the process of cleaning out all other kexts and only using the ones that it needs.  No change.
extract new send_me with last files
I really appreciate your help!
check if work
It worked!  I did have to remove the FakePCIID.kext though...  otherwise it would not boot.  Thanks very much!  Now I have my trackpad back.
enjoy
