Help!! Cant get HDMI Audio working on Mojave 10.14.6
Hi Everyone,
System:
Dell 1577 Laptop
Inter HD Graphics 630 + Nvidia GTX 1050
Intel i7  7700HQ Processor
Mojave 10.14.6
I have got the intel HD Graphics 630 fully working with working HDMI. I can't get Audio to work on HDMI (digital out). I have read loads of guides with not much luck. The audio works on internal speakers and headphones works using ALCPlug fix. I have AppleALC Kent  installed. I have tried changing the audio layout under devices to 5,11,13,14,21,22,28,56,57,66 and 97 which is for my codec Realtek ALC256 with no change at all. Im not sure but I think I have to install a Patched AppleHDA.kent which I can not find. I have also tried Voodoo.kent which brings up the option to select HDMI audio but I don't think it is supported for intel.
If someone could help me on this I would most grateful. Here is a link to my EFI file: https://1drv.ms/u/s!AvHg6s4Jf3C1gfBnQgcPcbCB_A37OQ?e=byD8lR
Edited by Tomprescott_128
u need a video patch by hackintool
8 minutes ago, Tomprescott_128 said:
Is there a guide on how to do this? I have had a look at Hackintool but not sure what settings to use to do this.
https://translate.google.com/translate?js=n&sl=auto&tl=en&u=https://blog.daliansky.net/Intel-FB-Patcher-tutorial-and-insertion-pose.html
I have managed to solve this problem. I used Hackintool to patch correct ID layout for my audio card. Then I used ALCbeta in boot argument in clover and installed fakePCIID with fakePCIID Intel HDMI Audio Kent. This method worked for me.
