Help with Hackintosh
Guest StarSix
Hello guys, I'm not that experienced with Hackintoshs (except my laptop), which is why I would rather ask here before I break more than repair haha
my system consists of:
Mainboard: Medion MS 7797
CPU: Intel Xeon E3-1240 Sandy Bridge
RAM: 8 GB
GPU: AMD RX 470 4GB
I did some research and found an EFI folder from Herr that seems to be compatible with my CPU
so I took my boot stick from my laptop and replaced the EFI folder
So the system booted and I was able to install it too, but unfortunately there are problems in a few places that I can't solve on my own
1. The sound doesn't work, I've done some research and found that I probably have the ALC 887 if that should help
2. My PS2 mouse is not working, which is why I had to switch to my half-broken USB mouse. Maybe that can be repaired with the VodooPS2Controller or something
I haven't found anything else yet, which can also be due to the fact that the two problems mentioned above have given me a headache
Any help is welcome and I apologize in advance for being such a noob xD
