hi, sorry if this is not the right section but don't understand where to ask, how to create an executable script for terminal .sh or executable by automator for the command.
pmset -g log | grep -e "Sleep" -e "Wake"
without having to type it every time in the terminal
thank
dell xps13 9360
core i7
Intel HD620
-ram 8 gb ddr3
-hard disk da 256 gb SDD
use .command extension
just keep it in notes.... copy and paste or take a look in downloads for/ at the disable hibernation.zip - unzip and look at contents in text editor and use as a sample to modify.
Start.command.zip
use one good txt app like TextMate
Enjoy!
