Hi,all.
I have a laptop Pegatron-A17
CPU:Intel core i7-2670QM(Sandybridge)
Graphics:Intel HD3000 Graphics
Memory:4GiB(Sumsung)
Display:Inner-LCD(1920x1080)&HDMI out
Wireresscard:Atheros ar9285
HDD:SDD(128GiB)x2
Audio:Intel HDAudio(Conexant)
USB:Intel 6 inner & Runessus USB3.0
OS:Windows7Ultimate(x64)&Mac OSX 10.7.2
Keyboard:PS/2(Built in)
Mouse:Logitech & TouchPad
i tryed fixed fixed attached dsdt.but,does not work Intel HD3000 Graphics&Intel HDAudio.
Someone please help me! I can't know what's problems.
Thanks so match read and sorry handicap English.
DSDTandOthers.zip
20120119.zip
The DualLink patch doesn't seem right, use the one from here http://Olarila.com/forum/patches.php
You can use Atheros 9285 patch, change name_adr 0x00 to name_adr Zero if it doesn't apply.
For audio you also need patched AppleHDA or use VoodooHDA.
hi,Cassio.
Thank you so mach good reply.
I miss fix DualLink patch.
i work repatching DualLink patch.
so HD3000 work! :o
i change Atheros 9285 patch name_adr 0x00 to name_adr Zero.
Atheros 9285 fully work !
but,HD3000 does not work QE/CI.
have you any idea?
DualLink patch is still wrong for me, check the link I provided.
hi
only in 10.7.2 have support to hd 3000
and check
AppleIntelSNBGraphicsFB.kext to see if u dev id is right
in pcimatch are some dev id like this 01168086 and must be 0x01168086
to have qe/ci
