Problem with GPU performance Ryzen 3600 + Nvidia
vinqu
Hello. Someone using AMD + Nvidia and dont have any problems? I have B450 Tomahawk Max + Ryzen 5 3600 with Nvidia GTX 1070 Ti and have problem with performance on games/openGL etc.. if i turn Geebench 5 on Graphic Card OpenCL test this closing benchmark after 15 seconds. System working normally but games and benchmarks no. LuxMark have 17,5k, Geekbench 5 Metal have 22k points (normal value is 50-55k for this card) What is going on guys?
On my previous PC with Z270 Gaming K3 + i7 6700k dont have that problems.
Link to comment
Share on other sites
AMD processors don't have native support, is a big shit for MacOs
if u need a professional build use intel ever
Link to comment
But i dont have any problems with processor. On processor i have better scores on mac than windows. Problem have with NVIDIA Card. Performance system are good but on OpenCL or games is poor.
Link to comment
I had the same problem on one old build. The system worked normally, but as soon as I started geekbench or Heartstone or Warcraft, the fans on the graphics increased RPM and after a while loop boot .. U have only low results or this programs crash?
When I replaced the power supply, the problems disappeared ...Of course, this may not be your problem, but if you have a chance to test it with another power supply, I would
Edited by intommy
Build 1: Intel i5-6600 Skylake, GA-B150m-D3H, 8GB DDR4, ASROCK Radeon RX 590 Phantom Gaming X 8G OC,  512GB - LENSE20512GMSP34MEAT2TA (NVMe) - windows / Patriot Burst 240 Sata macOS Catalina, Fractal Design Meshify C Mini Dark TG, Corsair RM650x, Catalina 10.15.4./ Win10  Build 2: Toshiba Tecra z40-c-11e, Intel Core i5 6200U Skylake, 8GB DDR3, Intel HD Graphics 520, Kingston UV500 240GB (SUV500/240G), BroadCom BCM94360CS2  + 12+6 Pin WIFI wireless card module to NGFF M.2,, Catalina 10.15.4  Build 3: Optiplex 790, Intel Core i3 (2nd Gen) 2120 / 3,3GHz, Intel Q65 Express, 8GB DDR3 (4x2GB), MSI GTX 760 - 2GB, Patriot Burst SSD 120GB, BroadCom BCM94360CS2  + 12+6 Pin WIFI wireless card module to NGFF M.2, Catalina 10.15.4. Build 4: Lenovo L340-15IRH Gaming Laptop - Type 81LK (81LK0034CK), Intel Core i5 9300H (2,40-4,10GHz), 8GB DDR4 2400MHz (1x8), Intel UHD Graphics 630, Catalina 10.15.4 / Windows 10 (Patriot Burst 240GB SATA3 SSD / M.2 PCIe SSD 512GB), DW1820a, atm not work: Wifi 5GHz, only 2,4 and BT.
Link to comment
Yes on low result on GeekBench. Only on Mac. On windows/linux dont have that problem then this is not power suply.
Link to comment
