Currently can’t get audio working I’ve tried Applealc and tried all the numbers for my audio device. I had it working at 99 rebooted and now won’t work on any number. I’ve also tried voodoohda and that won’t work either.
also trying to get my micro sd card reader working. I’ve heard USB ones can be a pain but mine doesn’t show up in usbmap, I believe it is a pci device. Any guidance on either issue please help I’m getting no where and most people give me one step and never get back to me with what to do next.
latte panda alpha cpu m3-8100y, gpu uhd 615, running Catalina
On 2/3/2020 at 6:51 PM, MaLd0n said:
Hey so i ended up getting my sound workingso im still having the following issues:
- Micro SD card reader isn't working
- usb camera isnt working (when i first installed catalina it worked with facetime calls, however the calls wouldnt connect you could just see the video. Now its a black screen and it tells me video not detected. The camera works fine in windows though.
If you see anyuthing please let me know i really want to get these issues fixed
Send me MacBook.zip
ur config is very wrong, use Olarila folder
Guest Kasek55
Really? Everything is running great, I’ve had 2 others end up looking at it and said it’s good. What parts specifically? And olarila folder is it in the post for Catalina guide There?
Only issue I have is the sd card not working
u need check ur logs, not if system is running, clover and oc is good and our system running, i'm talking about one hack like one real mac
Guest Kasek55
How would one read the logs? I’m new to all this so not really sure how to go about this.
I’ve been reading some forums and that and apparently my sd card reader is intel and that’s why it doesn’t work. Not sure if this is fully accurate but that’s what I’ve been seeing.
