Hi,
I have no audio on on my mackintosh (Macos sierra 10.12.6 16G2136)
I have my speakers plugged in, but it will be the best if the audio comes out from my monitor (hdmi audio), which has a jack port where I connect my headphones.
Thanks!
Hi There! Thanks for the kind help!
I lately found out that I had an ALC887, not an ALC892 how it was wrote on the MSI website.
The layout Number 5 worked for me, and the audio is working perfectly.
It would be the best if it's possible to make my headphones working.
They're connected to a jack port that is in the monitor (the audio passes trough the HDMI cable).
This is what DCPI Manager tells me:
<IMGUR id="ZA8bf8M"><a href=https://i.imgur.com/ZA8bf8M.png' alt='IMGUR>'>
try other layout-id
u can use a codeccomander too
