Hi everyone,
Right now I'm stuck at the patching phase, which requires a lot of patching. Right now I'm trying to patch trackpad and sound at the moment. For trackpad, my hardware is I2C which requires Voodoo I2C kexts. I followed through their tutorial but I'm stuck at Missing SSCN or FMCN bus speed config. I followed some guides around but nothing works. Would appreciate any help given.
For audio, I had VoodooHDA only loaded in KEXTS/OTHER and it worked, but only headphones works and the rest of the output doesn't work at all. Now I have put AppleALC into /S/L/E and now it broke my audio and nothing works. My audio codec is Realtek ALC294.
I would appreciate any help given. Especially DSDT patching, which took me a whole day to fiddle with and still doesn't work.. I will attach VoodooI2C full info archive and also my RunMe files.
Spec Overview:
ASUS Strix ROG G531GD-1050
CPU: i5-9300H
RAM: 12GB DDR4 2667MHz
GPU: Intel UHD 630 + GTX 1050
Trackpad Info:
ETPD
ELAN 1203
[GPID Codes]
#define GPP_C23_IRQ 0x5f
#define GPP_C23 74
static const struct intel_padgroup cnlh_community1_gpps[] = {
CNL_GPP(0, 51, 74, 64), /* GPP_C */
0x57'
#define GPP_H23_IRQ 0x5f
#define GPP_H23 202
static const struct intel_padgroup cnlh_community3_gpps[] = {
CNL_GPP(1, 179, 202, 224), /* GPP_H */
0xF8 / 0xF7
#define GPP_K23_IRQ 0x5f
#define GPP_K23 178
CNL_GPP(0, 155, 178, 192), /* GPP_K */
0xD4 / 0xD7
0x17, 0x1B, 0x34 and 0x55.
RunMe.app Files: https://www11.zippyshare.com/v/QVWTvSy0/file.html
VoodooI2C Troubleshooting.zip
Hi! Thank you for helping with the patch, now I have a working battery indicator, but the touchpad and sound is still not working, any recommendations?
useful links in my signature
I have tried fixing audio with VoodooHDA and AppleALC, with injecting but both doesn't work. VoodooHDA works only with headphones not speakers. VoodooI2C doesn't work and keeps spitting out errors.
