How to fix the sleep in laptop ASUS A407UF, hemm i need suggestion to this, thanks :help
spec:
-Intel® Core™ i5 8250U Processor 1.6 GHz (up to 3.4 GHz)
-8GB Ram DDR4
-14.0" (16:9) LED-backlit HD (1366x768) Anti-Glare 60Hz Panel with 45% NTSC
-Integrated Intel HD Graphics 620
-Hard drive:
1TB 5400 rpm SATA HDD
-Solid state drive NVME:
256GB SATA 3.0 SSD
-Nvidia MX130
post one full dump
--Run_Me
RunMe.app
Hai i have the same spec with your laptop and i have the same problem
first, use macbookpro15,2 smbios
second, ur config is very very wrong
